Q7 Front Grille with ACC Sensors Vs. Normal Q7 Grille without ACC sensors
Old 04-06-2014, 03:40 PM
RS3_Hopeful's Avatar
Default Q7 Front Grille with ACC Sensors Vs. Normal Q7 Grille without ACC sensors
Hi All,
I was wondering whether a normal Q7 front grille (2011, facelift model) can be modified to accommodate the Adaptive/Radar Cruise Control sensors that sit on the ACC grille?
The reason I ask this is because I have Q7 (TDI, 2011, UK-spec) with the Adaptive Cruise Control option and I want to change-out the existing chrome-strip grille for the Black Optic matte-finish factory-spec grill. However, this Black Optic grill is coming of a 2014 Q7 which does not have the ACC option and so is the normal grille. So, can this be modified to accommodate the existing ACC sensors present on my vehicle?
I hope the question is clear, thank you for any advice.
Cheers,
R
Old 04-06-2014, 03:55 PM
B490MTL's Avatar
There is clearly two different part numbers, also the front grill filler needs to be the right one with the heating element behind.
Old 04-07-2014, 05:08 AM
Thanks for the reply.
I understand that there would be two different part numbers, however are you aware if the normal grille (without ACC) be modified easily to accommodate the ACC sensors?
I didn't know about the heating element behind the grille - what purpose does this serve and is it present only on the ACC grille?
Apologies if any of the questions are basic..
Cheers,
R
Old 04-07-2014, 05:31 AM
B490MTL's Avatar
The heating element is to remove snow/ice buildup to keep the radar functioning properly. For how to modify the grill I guess you'll have to wait for someone who has done this mod before.
Old 04-07-2014, 06:42 AM
Thanks for confirming.
In that case, I may just take a punt and see what happens. If I do, will post the results here.
Cheers,
R
Old 04-17-2014, 05:16 AM
Hi, do you know the correct part number for the Black Optic ACC-ready Grille?
Cheers,
R
Old 04-17-2014, 08:50 AM
B490MTL's Avatar
You'll have to give a call to your dealer, I tried to look on Jim Ellis Audi parts website but can't get to the grill part number.
nirad
TT (Mk2) Discussion
08-30-2007 09:44 AM
mattchow
08-28-2002 09:26 PM
hoTTub
TT (Mk1) Discussion
07-13-2001 03:59 PM
JCJiffy
09-08-2000 09:29 AM
Quick Reply: Q7 Front Grille with ACC Sensors Vs. Normal Q7 Grille without ACC sensors
