Can anyone identify this part?
Trying to figure out what this is exactly so I can fix it. Small speaker I believe, on the b-pillar just behind the passenger seat. It has started making a "white noise" sound after turning the car off followed by a loud pop a minute or two later. Extremely irritating. Your help is appreciated
It does have OnStar. Not active obviously as I guess the technology is too old. Its a 2004.
I did just recently have to replace the battery and I'm waiting on my Ross-Tech vag-com to arrive to recode it. Not sure if it's related. Been going on for a while.
That is part of the OnStar system. Pull the fuse for the OnStar system. The OnStar module has an internal battery that will take a week to drain. Or, pop that grill off and disconnect the wires.
Okay awesome! Glad to know it's something I don't need at all. I'll give that a shot. Thanks for the help
Update:
Got my Ross-Tech VCDS in yesterday and got a full scan. New battery is coded and seems to be working properly. Still having this issue with the emergency battery and static noise.
Will the backup battery recharge now with a new coded battery and just take some time? (I replaced the main battery a week ago and just recently re coded w/VCDS)
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3005798
Coding: 0000005
Shop #: WSC 23436 444 53498
VCID: E0CFD9AF3091591E743-5140
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
I did try to find a fuse for OnStar and didn't find anything listed in the owners manual. I'm guessing that it's embedded with another system.
Off topic slightly but is there a way to update our antique OnStar? Haven't found anything on it in the forum but it would be nice to have for my wife's "prego brain"
LOVE THE VCDS!!!
Coding: 0000005
1 Fault Found:
LOVE THE VCDS!!!
I can live without OnStar & bluetooth, no problem. Will the emergency battery eventually charge back up and stop the speaker static and popping noise?
I don't think so. If it was rechargeable it wouldn't be down at all. It has nothing to do with battery coding. I don't think that is the cause for the static noise. I had same module and dead battery but I didn't have any such noise. Pop out that thing and unplug it.
I do see your point if the backup battery doesn't charge from the alternator or is plain worn out like the start battery was.
I'm not 100% opposed to just pulling a fuse like Mister Bally suggested if I can ID the correct one. Is OnStar going to be lumped in with a telematics fuse perhaps? And will there be any faults/repercussions from pulling the fuse once I find it?
This car is WAY more electrically integrated than I'm used to. Makes me timid to do anything on it and I'm a decent mechanic.
Thanks for all the help guys!
