I know this might be a stupid question, but humor me
Old 12-05-2013, 11:25 AM
spijun's Avatar
Originally Posted by scrmorling
Seriously? Same valving on the supercharger? Same inlet manifold? Same exhaust manifold? Clearly, the exhaust system is different somewhere along its path to accommodate the dual tips.
The SQ5 also has the Soundaktor which has be worth a few HP (j/k).
Steve
I do not have time to look for each part, because there are thousands.
Of course there are some small differences,but anything significant
As you can see these are all the same parts
Old 12-05-2013, 11:39 AM
spijun's Avatar
Originally Posted by Buckeye96
So what would happen if I found an SQ5 in a wrecking yard and was able to pull the hardware?
It is impossible due to coding and SVM (Softvare Version Management) which is adapted to your hardware.
There is a possibility but you must find the Audi hackers
I know two, but they in Europe OPSSSS I'm not that
Old 12-05-2013, 11:41 AM
spijun's Avatar
Originally Posted by Parsec
It means you're sleeping because that would only happen in your dreams.
Nothing is impossible, believe me
Old 12-05-2013, 12:53 PM
tomaszp72's Avatar
Didn't someone once say there are no stupid questions, only stupid answers? Anyway, isn't there a little more to an SQ5 motor than a different chip? I thought it had a different supercharger, plumbing, .... Spijun any specifics? Steve
It is exactly the same 3.0T engine across different models with a different tune. The same blower.
Go right away for Stage2 if you are going to tune it, stage1 is not worth it. Stage2 will give you pretty much SQ5 numbers.
If you are buying new it makes more sense to just go for the SQ5.
Old 12-05-2013, 02:19 PM
MP4.2+6.0's Avatar
Default Still , be careful in here...
even if the motor internals all basically line up, my instinct is you will still run into issues, at least for the CEL coming on--which then means you can't pass smog. For example, I expect it would likely look at the various sensors and see a gear ratio issue (assuming SQ's are geared differently; common on Audi S models in general). That probably throws a CEL; car will mistakenly think there is a tranny issue since it would be looking for the wrong gear ratio. Of course if monitoring is solely in the TCU and not ECU, then maybe ok, but my prior experience is they are interlinked pretty tightly.
As spijun said in one of the other replies, I bet you would have to hack into the box to really get it right. And in the modern age, even if it bolts up or plugs in, often that simple CEL issue coming from one of the drivetrain monitored systems/sensors where something doesn't match up can be the show stopper.
audiinnj
A4 (B8 Platform) Discussion
9
12-05-2018 04:31 AM
dth930
Telematics Discussion
09-29-2015 07:06 AM
mug23
09-27-2015 10:28 AM
myroad
Audi A3 / S3 / RS 3 MKII
10
09-17-2015 06:41 PM
bilbo6209
09-09-2015 01:28 PM
Quick Reply: I know this might be a stupid question, but humor me
