Update: Water in passenger footwell.
Old 12-13-2004, 09:49 PM
Junior Member
fl2.7T's Avatar
Ah! My old 16" inch wheels. I could have lived with them if they were 17".
Old 12-14-2004, 03:35 AM
OCDboy's Avatar
Winter wheels!
Old 12-14-2004, 05:11 AM
TeddyBGame's Avatar
Default If you had your windshield replaced recently....then they would've removed that
black plastic piece to pull out the old windshield.
Good catch!
-ted
Old 02-27-2009, 08:25 AM
baco99's Avatar
Default Re: Amen to that. You might what to check under the carpet too - see my old post...
FWIW...I had to have the TCU replaced because of this and now I am diagnosing the same problem...
Old 05-24-2014, 07:46 AM
Daniel T. Barrett's Avatar
Default water in passenger cabin Transmission control module
inches of water on floor on passenger side. transmission acting funny, sticking in 4th gear. Many days to find problem with engine compartment drain underneath battery. A few hundred dollars for service guy to clean contacts and dry out TCM. But, it worked and could've been worse. Hope this helps somebody.
Old 05-24-2014, 07:47 AM
the battery compartment filled to the level where it overflowed into fresh air plenum and into passenger cabin floor.
Old 05-24-2014, 10:13 AM
Zaphodb17's Avatar
I had the same thing happen to my C5 A6, and I tried everthing that I've seen on this site, but it turned out that summertime sunlight had heated the black plastic shroud at the base of the windshield, distorting the form of it. There was no way to get it to mate back up with the windshield/base and everytime I went through a carwash or left the car out in a rainstorm, water would run down the windshield, pool on the opened lip and dump directly through the pollen filter onto the floor of the passenger footwell. I solved the problem by cleaning the plastic shroud mating surface and windshield/base mating surface with lacquer thinner and gluing it all together with black RTV silicone. I've not had this problem since. It's interesting to note that the driver's side shroud has no such distortion and fits perfectly to exclude water. Of course there's no pollen filter for any escaping water to flow through on that side.
Old 05-06-2019, 08:18 AM
  #18
JustinHeber's Avatar
For such leak detection issues you should read the manual guide to prevent leaks.
davecr
Q5/SQ5 MKI (8R) Discussion
20
02-11-2022 09:55 AM
cameltrophyallroad
Audi allroad
09-23-2013 07:01 PM
adsquare
10-28-2009 02:23 PM
JMURP
10-15-2005 02:36 PM
Dr.quattro
Audi allroad
9
01-22-2004 01:37 PM
Quick Reply: Update: Water in passenger footwell.
