I know this might be a stupid question, but humor me
Old 12-05-2013, 04:33 AM
Buckeye96's Avatar
Default I know this might be a stupid question, but humor me
I was thinking about chipping the 3.0T on my Q5 but don't want to do it to early and void the warranty. Then I got to thinking, can you source a SQ5 "chip" and replace it the Q5? Would that throw codes? Is it even possible?
Old 12-05-2013, 05:08 AM
Club AutoUnion
scrmorling's Avatar
Didn't someone once say there are no stupid questions, only stupid answers? Anyway, isn't there a little more to an SQ5 motor than a different chip? I thought it had a different supercharger, plumbing, .... Spijun any specifics? Steve
Old 12-05-2013, 05:54 AM
Transfer's Avatar
Cool idea, but I would bet heavily against it working. Along the same lines though, you could maybe get two Q5 3.0T ECUs and swap a tuned and stock one around. It's probably a monster PITA to do though. You're smart to be wary of a tune if you value your warranty though.
Old 12-05-2013, 06:45 AM
spijun's Avatar
Believe it or not in models Q5 and SQ5: the same engine, fuel pump, fuel rail, injector, compressor....
The only difference that I found is that the SQ model has additional radiator
Q5 3.0 (272PS)/(354PS) eng. code:CTVA,CTUC / CTXA,CTUD
Who wants chipping the on Q5 3.0T :
http://www.goapr.com/products/ecu_up...30tfsi_q5.html
Old 12-05-2013, 08:40 AM
BlackSVT's Avatar
Nope, I know some have mentioned maybe different crank, rods, etc between 3.0T and SQ5, but nothing different has been found in the parts database other than the radiator that I'm aware of.
Audi has been "tiering" engines with software controls/restrictions for a while now it seems. In the Q5 3.0T case, it seems to mostly be in the form of more boost bleed-off on ordinary Q5s vs not on the SQ5. The supercharger is the same unit on both.
Old 12-05-2013, 09:11 AM
Buckeye96's Avatar
So is it possible? And has anyone tried? I'm thinking that if it was an official Audi tune then it would be less likely to throw a code.
Also, is it a physical chip or just a software upgrade to the existing hardware?
Spijun -- is there a specific part number for the SQ5 chip?
Old 12-05-2013, 09:40 AM
spijun's Avatar
This is a control module for all petrol engines hardware is the same, only difference in the software
There is one problem, it's empty hardware and software goes online directly from Germany
Old 12-05-2013, 10:40 AM
Club AutoUnion
scrmorling's Avatar
Seriously? Same valving on the supercharger? Same inlet manifold? Same exhaust manifold? Clearly, the exhaust system is different somewhere along its path to accommodate the dual tips.
The SQ5 also has the Soundaktor which has be worth a few HP (j/k).
Steve
Old 12-05-2013, 10:59 AM
Buckeye96's Avatar
So what would happen if I found an SQ5 in a wrecking yard and was able to pull the hardware?
Old 12-05-2013, 11:13 AM
Parsec's Avatar
It means you're sleeping because that would only happen in your dreams.
Quick Reply: I know this might be a stupid question, but humor me
