1997 A8Q starts then dies
Had the D/S head off (thus also intake manifold, front end etc) for a heli-coil. Did timing belt with Blauparts' tools. Once I got the engine speed sensor hooked up the car starts great, then runs a little while, stumbles, and dies without throwing a code. No codes are set except AT 17087, brake light switch. We can put that aside for now, perhaps I just didn't push the pedal at the right time.
I'm told this is commonly a vac problem. Anyone have a good pic/diagram of the vacuum clusterfail at the back of the intake manifold?
Also the fan switches on and won't stop when I switch on the ignition. Did I connect it to the wrong connector or something? I noticed that although most of these connectors are keyed or at least available in a keyed variant which I've seen on another car, they didn't bother to use connectors with alternating keys in alternating locations so you can plug some connectors in incorrectly...
Mister Bally
12-08-2013 06:54 PM
chiefironbear
12-06-2012 04:33 AM
