Intake Manifold Linkage Arms - Unbreakable Replacements
Old 03-29-2011, 09:15 PM
  #21
MrMoneyPenny's Avatar
Default Excellent
Especially the illustration to understand the inside mechanics, is very helpful to visulaize.
Now I just have to translate this into Mandarin ;-)
Cheers
Old 03-30-2011, 05:29 AM
  #22
Default Can you use
Originally Posted by luzarj
Could you send the link or webpage to your picture posting on the Intake Runner maintenance to free up the stuck runners. I am going to first go with the Sea Foam in the intake, but wanted to see what the full job looks like.
Thank you,
Jason Luzar
Can you use WD-40 to loosen the spring? Sorry but I don't think we get Sea Foam here in Asia.
Old 03-30-2011, 02:15 PM
  #23
mattsimis's Avatar
Originally Posted by silverd2
https://www.audiworld.com/forums/sho....php?t=2801728
Not a bad tutorial...even if I do say so myself
Ever any confirmation if this affects the 32v engines too?
Old 04-05-2011, 07:45 AM
  #24
Former Vendor
gruvenparts.com's Avatar
Thanks to all for the helpful replies on this thread.
We can post a DIY on www.GruvenParts.com or even on our product page for the intake link arms if you guys want.
While we are looking at this, what other items need the "billet" treatement on these cars? Feel free to email me directly with suggestions.
As always, those who bring us new ideas get new parts to try out.
Its exactly how these came about
Paul@GruvenParts.com
www.GruvenParts.com
Audi/VW 4.2V8 Intake Linkage Arms !
OEM P/N 077198327A (077-198-327A)
Old 02-16-2012, 11:29 AM
  #25
cemenacho's Avatar
I just rec;d the rods from gruvenparts- they look real nice, high quality. while I'm replacing them it makes sense to clean everything up and replace o-rings and seals. I was wondering if anybody knows of anyone who sells the o rings and seals around the intake manifold rods? I went to the dealer and they told me the only way to get those parts is to order a new intake manifold (for $1300)- yeah right. It seems crazy to me that these small service parts cannot be purchased
Old 02-16-2012, 05:11 PM
  #26
Perpetual Novice's Avatar
Originally Posted by invisiblewave
I just can't see how there's ever enough pressure or leverage there to break the arm.
believe it or not, those little diaphrams can pull about 40 lbs force on that tiny arm. the problem is caused by the magnesium castings that surround the black plastic arms corroding, and then the arms start to bind.
Gruven, do you make an oil cooler pipe replacement? have you considered making replacements for the magnesium castings (see silver's pic)
Old 02-16-2012, 06:06 PM
  #27
silverd2's Avatar
This guy (Fusilier)...click on his title for email:
http://forums.quattroworld.com/a8/msgs/56913.phtml
Old 02-20-2012, 10:24 AM
  #28
Former Vendor
If you guys want us to make the oil cooler pipe, I will be happy to. Please email me directly. Whoever helps will get free parts - paul@gruvenparts.com
As for the seals, again, if you cannot find them locally, let us know. The same deal goes for the seals. Email us.
Paul@gruvenparts.com
www.GruvenParts.com
404-556-6663
QUOTE=Perpetual Novice;24263202]believe it or not, those little diaphrams can pull about 40 lbs force on that tiny arm. the problem is caused by the magnesium castings that surround the black plastic arms corroding, and then the arms start to bind.
Gruven, do you make an oil cooler pipe replacement? have you considered making replacements for the magnesium castings (see silver's pic)[/QUOTE]
Old 02-20-2012, 10:51 AM
  #29
well turns out I don't need one after all, thanks.
Old 09-21-2012, 07:40 AM
  #30
Former Vendor
just wanted to bump this thread back to the top. we now have a handy DIY on the product page of the site which will help you in replacing and cleaning the manifold to ensure it works properly.
Can someone post a source for the vacuum pod itself? I have had several ask me for a source, i thought it was also available for certain cruise control systems on Land Rover vehicles, and it was very inexpensive. Can someone post that info to help others avoid the Audi dealer entirely !? I will include the info in the DIY article on our product page.
GruvenParts.com 4.2L V8 Intake Manifold Linkage Arms Warranted for Life !
Got a 4.2L V8 Audi or VW ? Then you had better check your intake manifold actuator arms Audi/VW P/N 077-198-327A (077198327A)! The OEM plastic versions quickly break, leaving your intake manifold rod stuck which causes poor idle, drivability, loss of power, and poor fuel mileage. This is a very common problem on the Audi/VW 4.2L V8, an otherwise great engine. The dealer will only sell you a repair kit for nearly $400, and each repair kit only comes with 1 of each length linkage arm. If your vechicle has 2 broken linkage arms, you would need to buy 2 dealer repair kits (cost nearly $800)!
Our Billet intake manifold arms are made from aerospace grade 6061-T651 aluminum with specially machined black Delrin inserts to provide a perfect fit to the actuator *****. These parts are warrantied for life!
Dont go to the VW/Audi dealer and pay upwards of $400 for the new actuator kit when all you need are the arms (the actuators themselves rarely fail). And DONT pay that kind of money for another set of plastic arms that will break in quick order.
Go with GruvenParts.com and NEVER WORRY ABOUT THIS AGAIN !
Fits the following vehicles:
2004-2007 VW Phaeton V8
2003+ VW Touareg V8
2002-2004 Audi A6/Avant
1998-2004 Audi A6/S6 Quattro
2000+ Audi A8/S8 Quattro
Replaces OEM P/N 077198327A (077-198-327A)
Quick Reply: Intake Manifold Linkage Arms - Unbreakable Replacements
