S8 transmission recode - Success! :-)
Old 02-26-2014, 08:41 AM
  #41
CME's01S8's Avatar
Thanks guys. I know that the car would accepted both the 00132 and 01132 code. I am looking for the code that may help with our hard downshifts... Mainly 2-1. Do u know I'd the 01032 code eliminates those?
Old 02-26-2014, 08:42 AM
  #42
CME's01S8's Avatar
Sorry... Meant the 00132 code.
Old 02-26-2014, 08:51 AM
  #43
silverd2's Avatar
Soft coding will do nothing for hard downshifts. That is more likely an internal trans thing...pressure, lack of pressure, valve in valve body, etc..
Old 02-26-2014, 09:32 AM
  #44
S8ilver's Avatar
I had a clunk from 2-1 on stock coding. After my recode it was virtually gone. I could still feel the shift, but it was so much smoother and didn't give the nervous jolt that was there previously. Could it have changed the rev shift point to smooth it our perhaps?
Old 02-26-2014, 02:43 PM
  #45
CME's01S8's Avatar
Installed the 01132 code. Car seems to shift exactly the same. I hate how this thing shifts out of 1st gear so damn quick. Guess its a VW/Audi thing.
Maybe I will give the 00132 code a shot.
Old 03-10-2014, 03:31 AM
  #46
Canadagord's Avatar
Default Recoded
"S" mode (2002 and later) on the shifter eliminates 5th gear and is an aggressively different shift behaviour. Soft coding is a much more subtle difference in shifting, with the exception of adding total control of 1st gear...a HUGE plus, you'll find, to unleash the below-40mph monster. It will not replace "S" mode, but will provide a useful alternative while tip shifting.
So I recoded over the weekend to 00132 and it's soo cool... firstly, it seems to shift all that much quicker, and shift points seem to be a bit higher giving a seat of the pants more livelier car as silverd2 says. The steering wheel mounted shift buttons are now live all the time so there is no need of moving the gear leaver over into the tiptronic slot to change gears, simply hit the button on the wheel and it goes straight into tip... switches back into normal drive after 10 seconds or so... as you said not as brutal as is the sport setting...
Highly recommended...
gordo
Audiworld2016
07-01-2016 01:23 PM
Vijay
S6 (C7 Platform) Discussion
02-16-2014 03:39 PM
puunda
Audi allroad
9
08-19-2013 09:24 AM
A4Driver
A4 (B8 Platform) Discussion
04-13-2009 07:41 AM
MRBSA3
Audi A3 / S3 / RS 3
9
09-23-2006 09:01 AM
Quick Reply: S8 transmission recode - Success! :-)
