Wheel advice
Old 04-13-2014, 04:03 PM
dukeland's Avatar
Default Wheel advice
I am looking to replace my stock 18" wheel (prestige, non-sport, OEM springs) which has 245/45/18 18x8J ET39 tire/rim combo with an A5 titanium rotor wheels with 255/35/19 19x9J ET33 specs.
The rimsntires.com calculator shows that the new wheel will stick out 11 mm compared to the stock wheel.
However, using the 1010tires.com wheel offset calculator, the wheel will stick out 19 mm compared to the stock wheel.
Which one is correct? Unfortunately, can't test fit as the new wheels are in a different city.
Old 04-13-2014, 04:16 PM
mjfloyd1's Avatar
1010tires is correct. The one inch wider wheel would be half of that inch inward and the other half outward so that half inch is 12.7mm. Add to that the 6mm offset difference and the wheel sits outward 18.7mm compared to the original wheels.
Old 04-13-2014, 04:24 PM
tenspeed's Avatar
On the "Rims and Tires" calculator, you have the stock wheel on the left. Try swapping them.
Old 04-13-2014, 08:23 PM
dukeland's Avatar
Thanks
Rufio
Q7 MK 1 Discussion
09-28-2011 08:00 AM
MC Hammered
03-01-2009 02:22 PM
Sloooo4esT
Audi Original "S" Cars
05-15-2005 10:12 AM
Need4spdnb
Wheels & Tires Discussion
05-07-2004 07:44 AM
Quick Reply: Wheel advice
