Squeaky suspension - Audi A4
Hi - my A4 developed a squeak in the rear suspension a couple weeks ago. Every time I went over a bump, it was squeaking quite noticeably. Very annoying.
I took it to the dealer to have a look and they diagnosed the problem as the bump stops and mounts. Parts were ordered as they didn't have them in stock, but the estimate for the total repair was $657.
After I picked up the car from the garage, it has completely stopped squeaking.
So now I'm wondering if I still need the repair. Obviously, I'll ask the service dept. the same question - but is it possible they just lubricated the bump stops and mounts (not sure what those are). If so, I'm wondering if the resolution is likely to be temporary or if I should save myself $657 and skip the repair.
Any ideas?
Any ideas?
I had an '09 A4 that had continual rear suspension problems - fortunately it was a CPO so everything was covered because the problems were never resolved satisfactorily. The rear suspension in the '09's is a huge black mark on the model, because once you have a problem, it is likely the problems will multiply. I had two new bump/stops (they are on top of the shocks), two new shocks, and various other parts and the car still did not ride as it did when new. At one point, they found welds loose between the trunk and the wheel wells which were making noise going over bumps.
I'm sharing this with you so that you don't start burning money on the problem. My final solution was trading in the car, which was the best thing I ever did.
Honestly, I'm hoping I can wait until the next version of the A4 is available - B9..? - before I trade this one in.
gregp1962
06-14-2014 09:50 AM
D in Van BC
TT (Mk1) Discussion
05-28-2000 12:17 AM
