Can you disable the rear side marker led's?
Old 04-11-2014, 02:16 PM
  #31
Hockenheim's Avatar
Originally Posted by kdagher
I am going to post a new topic by the end of next week of how to convert US to EURO Tailights, with the full coding. I will also explain every single detail of every single code.
Has this been released? I really want to change my signals and brake lights to blink seperately like EU
Old 04-11-2014, 02:43 PM
  #32
kdagher's Avatar
yes it is released
https://www.audiworld.com/forums/sho....php?t=2864162
Old 04-12-2014, 05:13 PM
  #33
osideaudi's Avatar
I guess you backflipped then? Hope ur happy nd thankful
Thanks for the info. it was actually an ultra slow backflip and I just landed a few minutes ago.
Old 04-14-2014, 01:24 PM
  #34
Hockenheim's Avatar
I'm referring to
"I really want to change my signals and brake lights to blink seperately like EU"
Please clarify, is that all that is needed? "CHANNEL [195: 12 & 196: 44] and [203: 5 & 204: 37]"
Old 04-14-2014, 02:26 PM
  #35
kdagher's Avatar
I replied to your message
Old 04-15-2014, 03:40 PM
  #36
osideaudi's Avatar
So if I enter the EU turn signals setup for the rear side markers, the rear side markers will act only as turn signals?
Old 04-15-2014, 07:15 PM
  #37
kdagher's Avatar
100% correct
like this:
209:12
210:44
Old 02-24-2020, 12:57 PM
  #38
midcza's Avatar
It will work on the SQ5, but before you change the code, we need to find out which channel is for the side markers. its always by pair.
if you can post the values of the channels from 195-210, i can tell you which one is the SQ5 side markers channels.
Access [46] module, put 16017 in the security code, then go to adaptation, please post the values from channel 195 to 210 here.. I will tell you which two are the side markers, it easy to pin point what is what.. Each model may use different channels for side markers, therefore i need to know the values to help you
will that work on 2012 B8 Audi S4? Still fitting with converting US spec to EU to register my car... if this will work I will do 2 backflips with tight up legs
ilikeit
01-09-2016 09:24 AM
ilikeit
Pacific Northwest Discussion
11-20-2015 06:57 AM
scopeman07
A7
09-09-2015 03:27 AM
giuseppepat
09-02-2015 02:47 AM
Beena
A4 (B8 Platform) Discussion
09-02-2015 12:01 AM
Quick Reply: Can you disable the rear side marker led's?
