Can you disable the rear side marker led's?
#21
I am going to post a new topic by the end of next week of how to convert US to EURO Tailights, with the full coding. I will also explain every single detail of every single code.
You don't have to work with ROSS TECH, because i have the solution.
I am promising the entire community i will release it next week, i am waiting for the inner left tailight to arrive to complete the retrofit. Moreover i am doing further code testing, for features that we can activate.
Furthermore i am writing an excel sheet that i will be sharing with everyone and i hope it will be self explanatory.
I will also post a video Before and after
I am 100% confident that everyone will finally be pleased.
#22
#25
#26
It will work on the SQ5, but before you change the code, we need to find out which channel is for the side markers. its always by pair.
if you can post the values of the channels from 195-210, i can tell you which one is the SQ5 side markers channels.
Access [46] module, put 16017 in the security code, then go to adaptation, please post the values from channel 195 to 210 here.. I will tell you which two are the side markers, it easy to pin point what is what.. Each model may use different channels for side markers, therefore i need to know the values to help you
#27
#30
