3.0 CAT failure rate
Old 09-13-2013, 09:34 AM
Audiworld Senior Member
ajg617's Avatar
Default 3.0 CAT failure rate
Can anyone explain the technical reasons why the CATS fail so frequently and more quickly on the 3.0L engine compared to the 2.8 or 2.7T? I know that the coding is very restrictive and a flash has been offered for both the 2.8 and 2.7T - not for the 3.0, but the 3.0 still seems to be the worst (this according to Audi and my indy from experience). Just curious.
Thanks,
AJG
Old 09-13-2013, 12:46 PM
Audiworld Basic Sponsor
ECS Tuning-Audi's Avatar
Not exactly sure what you mean by "coding" but it may just be a manufacture defect.
Cats usually are the last to fail as it takes many many heat cycles to burn them out.
Or boosted engines the possibility of unburnt fuel to ignite in the cats is much more common than in NA motors. This can lead to premature failure or over heating as well.
Jason
Old 10-09-2013, 05:52 PM
ajg617's Avatar
Jason
Referring to this thread.
https://www.audiworld.com/forums/sho....php?t=2776642
I've seen the TSB for the 2.7T, not the 2.8. I have a 3.0. Been through this with GM on disc brake rotors. Recalled every model except mine - not enough sold to warrant a recall or TSB. My front rotor separated at the hub to braking surface joint at the composite weld. Every other 1500 model before and after was affected.
Old 10-10-2013, 11:42 AM
Prospeeder's Avatar
3.0 engines have the hideous red ignition coils that fail regularly, all it takes is a super hot cat, a missfire, and raw fuel hitting the cat to destroy it.
Old 10-13-2013, 01:42 PM
ajg617's Avatar
Well, I did have some coil problems earlier. Had to replace two, one on each bank. Then Audi recalled the vehicle and replaced them all. But that was after the Cats were throwing codes and at over 120K.
jenyus425
Audi allroad
16
06-05-2012 09:16 AM
dwitzel
10-09-2009 05:00 PM
HashamSyed
11-08-2004 12:15 PM
davrober93/100csq
Performance and Tuning
10-20-2002 07:03 PM
Quick Reply: 3.0 CAT failure rate
