Excess oil consumption
Old 04-15-2014, 06:01 PM
  #41
jr'sAudiA6's Avatar
Originally Posted by Mike_L
4k is completely normal for a quart. Some BMW TT V8s will use a quart every 2k, and I've gotten the "new" Hemi to go through a quart in about a thousand.
It depends how hard you drive. The harder you drive, the more oil it will use, both through the PCV and through the breather hose. Take the bypass elbow off your blower and you'll find it. It will REEK of oil when you remove that. I can't wait to get my hands on a spare blower from a 3.0T. I bet the intake plenum/manifold, intercooler cores and possibly the rotors will be coated in either oil or burnt on oil residue.
If what you are saying is true across the board then I should be using oil by the quarts considering how many track events I have been to, I push my A6 hard at these events. So far, after 41470 miles I have added a total of 1 quart in between oil changes.
Old 04-15-2014, 06:45 PM
  #42
Banned
Mike_L's Avatar
Are you going on and off throttle? Thats what does it, creating high vacuum in the manifold and the inlet tube. It literally sucks the oil out of the motor.
I'm down about half a quart in 1200 miles right now. Nobody beats on a car the way I do, with WOT, high rpms and hard braking constantly, so I wouldn't expect anybody else to use oil as fast, but it is possible. Thats why when Audi says 4k miles is normal, they're telling the truth. It just depends on the driver.
Old 04-15-2014, 07:54 PM
  #43
DeerHunter's Avatar
Makes sense. In daily-driving mode, I use no oil at all. When I took it to the track for an HPDE day, the electronic level went down by a third. I suspect, as MikeL postulates, that it's not going past the rings but is being blown out through the PCV and/or breather hose. The underside of my hood is coated with carbon.
Old 02-20-2017, 11:45 PM
  #44
marxs's Avatar
Hi All,
As I see ,all the comments are for 3.0T.
Any similar issues for 2.0T ,same year (2012/2013) ?
Thanks,
R
Old 02-27-2017, 09:31 AM
  #45
Diogenes's Avatar
Originally Posted by marxs
Hi All,
Thanks,
R
From my reading here, I think the oil consumption issues were pretty much resolved by then. I had a 2008 2.0 that needed rings replaced. Now I have a 2015. It is down about 60% in 8,000 miles. No complaints with that.
tigerfan
Q7 MKII Discussion
19
09-18-2017 07:39 AM
Gibber
03-25-2009 08:33 PM
pink shrimp
07-07-2006 10:08 AM
LMDA1
11
10-16-2000 04:18 PM
Roger B
05-11-1999 04:21 AM
Quick Reply: Excess oil consumption
