2009 A6 Avant turbo wagon burns oil
Old 01-24-2013, 09:09 AM
ccamargo's Avatar
Default 2009 A6 Avant turbo wagon burns oil
My 2009 A6 Avant turbo wagon burns oil. I have to put in a quart of oil every 5K miles. Is this typical? I had a 2001 A6 2.8 that burned oil occasionally.
Old 01-24-2013, 09:10 AM
ccamargo's Avatar
Does anyone else have this problem?
Old 01-24-2013, 09:24 AM
uberwgn's Avatar
our 2006 Avant consumes none. The engine isn't known to be thirsty for oil.
Old 02-20-2013, 05:17 PM
Prospeeder's Avatar
sheesh you should be changing the oil every 5-6k miles with synthetic on a turbo engine. Doing the ol 10-15k oil changes, dont expect the turbos or the engine to last very long after 100k....those intervals are to make a maintenance schedule on a new car look good, they could give a damn if it lasts any longer than the warranty. Same goes with your "lifetime" transmission fluid.
But 1 quart in 5k miles is very very normal, and i wouldnt worry about it at all. Audi seems to think its perfectly acceptable to burn 1 quart every 1000 miles....
Old 09-13-2013, 09:37 AM
Audiworld Senior Member
ajg617's Avatar
My 3.0L goes through a quart every 1500-1800 miles. 2nd quart tells me it's time to change the oil. Has always burned this amount. Am told it's unusual, but haven't been able to determine why.
Old 09-13-2013, 11:35 AM
Prospeeder's Avatar
Probably a failing crankcase vent valve, pretty easy to replace and fairly cheap. Could also be valve seals leaking, it seems to be common on Audi V6s
A4 to A8
22
08-28-2008 04:20 PM
expert47
10-14-2006 08:12 AM
Audi2525
12-03-2005 07:17 AM
Fcasadon
07-27-2005 04:00 AM
BklynA4
05-06-2004 11:46 AM
Quick Reply: 2009 A6 Avant turbo wagon burns oil
