Definitive List of A6 Vagcom Mods?
Old 04-10-2014, 11:56 AM
  #21
kdagher's Avatar
Originally Posted by manishaudi
For the Gear Display mod, a reboot is not necessary.
But if you wish to do it, it is done by pushing down the "Menu+Control ****+top right" buttons at the same time. Press all three at the same time then release.
How were you able to make lap timer work for you 2012 audi a6? I see from your signature you have lap timer on 2012. I tried to pm you..
Thank you
Old 04-11-2014, 12:31 PM
  #22
vigoureux's Avatar
Thank you
Guys my Euro-spec 2012 still has no gear display in D, and no lap timer. I tried everything mentioned here on this page
Old 04-11-2014, 02:46 PM
  #23
Hockenheim's Avatar
I have this same problem on my MY2012
Old 04-11-2014, 02:48 PM
  #24
kdagher's Avatar
My gear display is working on my 2012, but not the LAP TIMER :@
Old 04-11-2014, 03:26 PM
  #25
Hockenheim's Avatar
Does your gear display show small where the "D" usually is, or does it show above it larger where the digital speedometer is?
Old 04-11-2014, 04:26 PM
  #26
kdagher's Avatar
Instead of D, it displays D1, D2, D3... or S1 S2 S3...
Old 04-13-2014, 01:22 AM
  #27
vigoureux's Avatar
Do you think it's a Euro-spec vs US-spec difference?
My "D" is in it's usual place on the bottom line and no numbers.
Old 04-23-2014, 12:20 PM
  #28
Hockenheim's Avatar
Does anyone know how to get the lap timer to work on a 2012?????????????????????????????
Old 04-23-2014, 05:09 PM
  #29
TheNit's Avatar
I had my Audi mechanic put some mods in today (he just bought the unit out of his own money). They are most of the one's mentioned here but one that didn't work was the remote operation of the windows/sunroof. He did the mod as follows [46-Cent Conv]-[coding-07]-[long coding helper] changed Byte 2 bits 2 and 3 from 0 to 1. I read elsewhere that once this is done you go into the MMI (Car-windows-windows conv open ...) and enable the functions. When I go into my MMI there is no option for Windows. I have a 2013 2.0T A6. Is there another setting that has to be changed to get this to work? I have MMI version 649 if that matters.
Has anybody yet determined how to change the Comfort Turn Cycles setting (number of times turn signal blinks when doing lane change)?
Old 04-24-2014, 06:05 AM
  #30
13c7a6's Avatar
It depends on the version of the Instrument Cluster. You can find more info here:
http://www.stemei.de/pages/coding/au...turanzeige.php
My German is a bit rusty, but google translate may help.
Quick Reply: Definitive List of A6 Vagcom Mods?
