2009 A6 Avant turbo wagon burns oil
My 2009 A6 Avant turbo wagon burns oil. I have to put in a quart of oil every 5K miles. Is this typical? I had a 2001 A6 2.8 that burned oil occasionally.
our 2006 Avant consumes none. The engine isn't known to be thirsty for oil.
sheesh you should be changing the oil every 5-6k miles with synthetic on a turbo engine. Doing the ol 10-15k oil changes, dont expect the turbos or the engine to last very long after 100k....those intervals are to make a maintenance schedule on a new car look good, they could give a damn if it lasts any longer than the warranty. Same goes with your "lifetime" transmission fluid.
But 1 quart in 5k miles is very very normal, and i wouldnt worry about it at all. Audi seems to think its perfectly acceptable to burn 1 quart every 1000 miles....
Probably a failing crankcase vent valve, pretty easy to replace and fairly cheap. Could also be valve seals leaking, it seems to be common on Audi V6s
expert47
10-14-2006 08:12 AM
Fcasadon
07-27-2005 04:00 AM
