Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Audi A6 C6 Proper Transmission Fluid for A6 Zf Automatic<br>Important information to help you understand your Audi A6 C6.
- Audi Q5 How to Check and Change Automatic Transmission Fluid<br>Step by step instructions for do-it-yourself repairs.
Transmission Fluid Change?
#81
bballfreak,
I And i guess more of us would appreciate a list or more detailed scope of work for the ATF change im planning on doing mine as well but i just want to make sure i do it right. i have 05 4.2 c6 .
would really appreciate it.
happy easter everyone.
PC
PC
#82
Amsoil ATF Is Now An Approved Replacement For Audi G 060162 A2 Fluid
Amsoil ATF can now be used as a replacement for ZF LifeGuard 8/Audi / VW Oil No. G 060162 A1/A2/A6 ATF. Check it out at the Amsoil website. About one third the price of Lifeguard 8.
#83
im having my ATF changed by the dealer with the new (blue) fluid and software update.
the ext warranty is covering the cost $1600, there was a leak in the tranny pan. so i asked them to use the blue fluid and update it too.
hopefully that will solve the unusual acting up of the tranny. will keep you posted...
#84
#85
P.S update to blue and tcm update is done because mine Is not "running fine"
#86
Trans service (bump)
OK, looking to do the fluid change on my recently acquired 2005 A6 4.2, 127k miles. Not having problems, but preventative maintenance is a 'good thing'. Asked the local dealer about the service history of my car, to ascertain whether the software update was done or not. Of course, the reply was that 'the transmission is sealed, no service is required'. So, I'm pushing the issue, as the dealer should have service records to indicate whether the software was ever updated.
So, big questions: I'd prefer to do the change of the filter and fluid myself, but obviously the dealer will possibly have to do the software update. Is there much risk in changing the fluid and filter, then driving to the dealer the 23 miles to have them update the software? Or, vice-versa?
Is there a verdict on the various compatible ATF fluids? Lifeguard? Pentosin? Is there an equivalent for the 'original' (orange?) fluid? Seems like scouring the various postings doesn't really reveal a 'definitive' answer..
-Darryl
-Darryl
#88
You would be fine driving it home. I do find you crazy. In a sense that your not experiencing any issues yet you want to do te software update that requires the ludicrously expensive fluid. Why not do a traditional trans flush with some quality fluid and save your sanity as well as some well earned $$$! If my A8 wasn't experiencing issues I would have changed the fluid much later than I did; if at all. Either way I wouldn't have wanted the expensive route that grants me no positive effects vs. the standard.
And a trans flush every 35k...? Haha.
Please feed the dealer if your that ignorant.
#89
That being said, if I could conclusively identify a suitable fluid for the existing software, that would be 'good enough' for me.
The local Audi dealer has taken a position of ignorance on the TSB for the software update, claiming no knowledge of any such software update, and thus far, is reluctant to give me what service records my VIN number may have already applied. That's one of my concerns: If the new fluid has already been used, then I have to stick with that. If not, then I could use whatever the equivalent of the current is.
