Reduced Power - Lots of codes --- Help!
Old 04-11-2014, 01:43 PM
kylepet's Avatar
Default Reduced Power - Lots of codes --- Help!
2002 A6 Avant - 3.0 (I'm starting to dislike this engine)
Newbie poster, hoping to get some insight.
Driving down the highway and the EPC light and MIL come on with reduced power but still running reasonably well. Pull over check it out with no obvious issues. Starts back up and EPC and MIL come back on with reduced power but still drivable. 5 miles down the road it gets worse and worse. I'm close to home so pull off and take side streets home. It deteriorated to the point it would barely come off idle. Pulled over to let things cool off thinking it was a sensor. 15 minutes later it runs much better but EPC and MIL still on.
Get home and it has the following codes, none of which it has had prior:
11 Faults Found:
19756 - Exhaust Camshaft Position Sensor Bank 1 (G300)
P3300 - 002 - Short to Ground - MIL ON
17800 - Camshaft Position Sensor Bank 2 (G163)
P1392 - 001 - Open Short to Plus - MIL ON
17746 - Camshaft Position Sensor (G40)
P1338 - 001 - Open or Short to Plus - MIL ON
19759 - Exhaust Camshaft Position Sensor Bank 2 (G301)
P3303 - 001 - Open or Short to Plus - MIL ON
18041 - Accelerator Position Sensor 2 (G185)
P1633 - 002 - Signal too Low - MIL ON
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 - Implausible Signal - Intermittent
18321 - Pressure Sensor for Brake Boost (G294)
P1913 - 002 - Short to Ground - Intermittent
17796 - Control Module Malfunction - DBW Throttle Monitoring
P1388 - 008 - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - Intermittent
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean - Intermittent
16485 - Mass Air Flow Sensor (G70)
P0101 - 008 - Implausible Signal - MIL ON
I monitored all the throttle position sensors on measuring blocks and they seem okay. I cleared the codes and started it back up. Idles unstable but has only the following codes:
Did some research and suspect the cam position sensor circuit is bad. Planning on checking it out this weekend. Though I can't shake the feeling that the ECU went bad. I would appreciate feedback. Thanks!
Old 04-18-2014, 09:13 AM
snatchman's Avatar
11 Faults Found:
I am Curious to know what you found. I am having a similar issue with my 2002 A6 3.0. I found coolant in the ABS and ECU module wire harness, effectively trashing these to units. Hope your not having the same issue, I still have not track down the source of the coolant.
kylepet
VAG-COM Discussion
04-10-2014 12:49 PM
_muppet_
9
10-14-2011 08:52 AM
jwk2w
11-15-2010 04:27 AM
mgonyea
09-28-2006 08:06 AM
eventuallyblue
12-12-2004 08:35 PM
Quick Reply: Reduced Power - Lots of codes --- Help!
