APR Tune
Old 09-04-2013, 08:57 PM
sciblades's Avatar
Originally Posted by CreoS4
From what I understand, it doesn't work that way with the newer model years. The ECU is tied to the keys, so you would essentially need to go back to the Audi dealership to re-code the keys to the ECU each time you swap (and the dealer would figure out why).
less to do with keys more to do that your dsg is coded to your engine and visa versa. Plus audi will only code one ecu at a time so you can't have an extra one, well you can have an extra one but it will just be an expensive paper weight on your desk.
Old 09-05-2013, 04:19 AM
gatorguy7's Avatar
Originally Posted by subterFUSE
Could an APR tuned ECU be swapped with a stock ECU when going in for service? Or would Audi be wise to that?
Unfortunately as other have said it isn't a good idea to even attempt this. Flashing back to stock each time is the only reasonable option but if they can't ever flash through the OBDII port then it could get tedious really quick.
Old 09-05-2013, 05:14 AM
nobbyv's Avatar
Originally Posted by cagambler
Unfortunately, Audi is in the same position with the buyer that the IRS is with the taxpayer. If Audi says the problem is not covered by warranty, they don't have to prove anything. The buyer has to prove (by lawsuit, most likely) that the problem was not caused by the tune.
That's not technically true. The Magnuson-Moss Warranty Act actually puts the burden of proof on the warrantor to prove that a modification caused the defect.
In practice, you're right, there have been instances of dealers denying warranty claims due to modifications, sometimes with tenuous (at best) associations between the modification and the defect. These dealers are then in violation of the Act, at which time the only likely outlet for the consumer is litigation. But said litigation would have a high probability of being concluded in the consumer's favor.
Old 09-05-2013, 06:34 AM
FAST4DR S6's Avatar
Default APR responses to S6/S7 Concerns
These responses were posted on another forum. Not sure if this helps or confuses the situation even more. At the end of the day, I have always told the Shop Manger/Service Director that my car is tuned since the upfront honest approach is always the best approach.
If you retune the ECU to stock, all traces our software was on there are removed.
We will only ever flash you with the same same box code and revision as you had before.
So to clarify, the file flashed back to your ECU at an APR dealer is the same file you had before.
The dealer's software basically just sends out a message to the ECU and looks for an answer in response. If the answer is wrong, it gets flagged. Since it's back to stock, that doesn't happen. People across all the platforms have confirmed this to be true.
Old 09-09-2013, 06:17 AM
Dr.Aronis's Avatar
waiting on the coding for the A8L version of the 4.0 L turbo....
92 miles north of me....short drive .
Mike
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
dougpaper
A6 (C7 Platform) Discussion
10
12-20-2015 04:31 PM
Monsoonenough
10-03-2015 02:59 PM
ernestolopez
A4 (B8 Platform) Discussion
09-30-2015 08:29 AM
Quick Reply: APR Tune
