Cold Start Problem
#23
Audi A4 cold boot
Hi fellows,
Reggie, I've tried to start the engine with charger on the battery - no difference. Last night, I've noticed, that when I spray with screen wash liquid my ignition leads, while the engine is working, I can see some sparks to light out. This should be bad insulation I think, but my question is, is this related to my problem with the first ignition and could this drop down my thrust?
I have the same issue
Thanks ahead for your answers!
#24
#25
caused by the fuel retern line valve sticking slightly open and the pressure over hours drains off so starting difficult after until pressure back up , get your fuel tank at 1/4 full add two bottles of injector and fuel system cleaner and drive until tank almost empty then fill normally , this will clean out the check valve and injectors and your starting problem should be fixed , common Audi problem on gas and TDI , injectors need 10 psi on retern rail or they wont work properly vale supposed to hold it but when dirty or gummed up leaks .
#26
2 bottles of injector and fuel cleaner will solve at with a quarter of tank of gas , the usual problem is the check valve on the fuel retern rail get gummed and leaks the pressure away when engine off , injectors wont work unless there is 10 psi on the return rail , my Q7 same cleaner in probelm gone next day , before it could take 3 to 4 starts and at least 20 seconds of cranking before fire up , once fired up was fine but after 12 hours off , pig to start , two bottles of cleaner job done , but on a 1/4 of tank and 2 bottles so good concentrated cleaning of the fuel system takes place .
raiderrider
12
09-08-2015 05:46 AM
