Audi 100/A6 (C4 92-97) FAQ Digest
Old 01-26-2007, 08:02 AM
  #131
austinado16's Avatar
Default Engine Vacuum Diagram In Color
<center><img src="http://pictureposter.audiworld.com/57225/vacuum_diagram_bulletin_in_color_website.jpg"></center><p>Please note that the blue vacuum hose actually attaches to the left rear (driver's side) of the intake manifold at the round plastic (black) intake manifold change over valve.
Old 01-26-2007, 08:51 AM
  #132
Default .
Old 03-09-2007, 01:41 PM
  #133
DaveInSaltLake's Avatar
Default Alternate Link to What I'm Assuming is the same info...Link Sam posted is dead.
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/16336.phtml">https://forums.audiworld.com/a6100/msgs/16336.phtml</a</li></ul>
Old 03-09-2007, 02:01 PM
  #134
Member
Bmthorn's Avatar
Default More timing belt related material...
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/70120.phtml">https://forums.audiworld.com/a6100/msgs/70120.phtml</a></li></ul>
Old 03-13-2007, 12:41 PM
  #135
E-Town's Avatar
Default Daytime Running Lights, disabling (cdn models)
Disabling the daytime running lights on your Canadian model 100 is a fairly straightforward and easily reversible procedure.
1. Remove Relay J90(relay #7) from the underhood relay panel. This will disable the marker light portion of the DTRs.
2. Disconnect the headlight reduced load connection.
a. remove the under dash conector panel cover.
b. locate a small (inch long) round, brown connector (mine was actually yellow). It will have a yellow/black and a yellow/white wire coming out of one end.
c. disconnect this connector. I recommend taping it up to avoid rattling.
3. Turn on the ignition and check the lights. They should now only come on when you use the switch.<ul><li><a href="http://www.s-cars.org/postnuke/modules.php?op=modload&amp;name=News&amp;file=arti cle&amp;sid=76&amp;mode=thread&amp;order=0&amp;tho ld=0">Thanks to the UrS4 forums for this hint.</a></li></ul>
Old 03-19-2007, 09:33 AM
  #136
beep-beep's Avatar
Default Another Front O2 Sensor Replacement
<ul><li><a href="http://12v.org/maintenance/repairs/o2sens.php">From 12v.org</a></li></ul>
Old 03-19-2007, 09:34 AM
  #137
beep-beep's Avatar
Default Engine Coolant Temperature (ECT) sensor, checking
<ul><li><a href="http://12v.org/maintenance/repairs/ect.php">From 12v.org</a></li></ul>
Old 03-19-2007, 11:49 AM
  #138
Member
Bmthorn's Avatar
Default Variable Intermittent Wiper (from 20v.org)
<a href="https://forums.audiworld.com/a6100/msgs/70449.phtml">Variable Intermittent Wiper (from 20v.org)</a>
Old 03-19-2007, 12:20 PM
  #139
Member
Bmthorn's Avatar
Default Actually not many of the principals apply from the 90...
Wiring, wiper stalks, and circuit boards are all different.
<a href="https://forums.audiworld.com/a6100/msgs/51513.phtml">https://forums.audiworld.com/a6100/msgs/51513.phtml</a>
Old 04-25-2007, 07:18 AM
  #140
Default IC chime speaker replacement - photos and DIY procedure
<ul><li><a href="https://forums.audiworld.com/a6100/msgs/72160.phtml">https://forums.audiworld.com/a6100/msgs/72160.phtml</a</li></ul>
Quick Reply: Audi 100/A6 (C4 92-97) FAQ Digest
