What size (allen) hex head socket to remove axle?
Old 10-13-2005, 09:26 AM
AudiWorld Expert
Mark P's Avatar
I already edited ;-)
Old 10-13-2005, 09:32 AM
AudiWorld Expert
Mark P's Avatar
Default BTW, some (A4s at least) have a different sized bolt...
As we found out in the bearing replacement linked below. Also, I believe the replacement bolt was a 14mm Allen<ul><li><a href="https://forums.audiworld.com/a4/msgs/2282516.phtml">https://forums.audiworld.com/a4/msgs/2282516.phtml</a</li></ul>
Old 10-13-2005, 09:34 AM
AudiWorld Expert
Mark P's Avatar
Default as noted here....
"Step One is to remove the axle collar bolt. This is a 17mm Allen bolt on newer cars, on older cars, it's a 24mm NUT."
<img src="https://www.audiworld.com/tech/pics/wheel37-13.JPG"><ul><li><a href="https://www.audiworld.com/tech/wheel37.shtml">https://www.audiworld.com/tech/wheel37.shtml</a</li></ul>
crew219's Avatar
That's for early 1.8t A4s . . . up until 2001.5 or 2000 . . . one of the two.
Old 10-13-2005, 09:37 AM
Elder Member
BiturboBoy_V2.0_S3--'s Avatar
Default yes and its a PITA. make sure you leave teh car ont eh ground while loosening.
thing aint' coming off otherwise.
Old 10-13-2005, 10:27 AM
AudiWorld Expert
Mark P's Avatar
Default and getting the torque spec is equally as hard...
I think it's something like "80ft-lbs + 180deg".
that 180deg is near impossible - of course I didn't have a 4 foot bar like in that other pic
Old 10-13-2005, 10:35 AM
gk1
gk1's Avatar
Default 17mm socket driver
Only place I could find one that size was snap-on. However the replacement bolt required a 27mm or 1 1/16" hex socket.
FYI if you are going to remove/replace it, make sure to have a long a$$ breaker bar. I needed a 2 foot one with a 1 ft piece of pipe to get it off, and to tighten the new one back on.
Also watch the bolt that holds the upper control arms in place. (If you take it out) Mine was rusted solid as well as a friends. He beat his out after removing the entier steering nuckle. I used a 7-ton puller and a small sledge. PB Blaster did nothing.<ul><li><a href="http://buy1.snapon.com/catalog/item.asp?P65=&amp;tool=all&amp;item_ID=3198&amp;gr oup_ID=363&amp;store=snapon-store&amp;dir=catalog">Snap-on 17mm socket dirver SAM17E</a></li></ul>
jwick
09-21-2010 11:39 AM
pigred
12v V6 Discussion
11-22-2005 03:37 AM
alpine951
12
10-30-2005 07:37 PM
joseg
12-30-2001 10:13 AM
Quick Reply: What size (allen) hex head socket to remove axle?
