comfot control module symtoms but not it
Old 04-07-2014, 01:02 PM
  #21
Airbag's Avatar
Originally Posted by jcman
I'm sorry I meant a former AW member 2.7Lturbo most of the timers remember him and most others couldn't forget, he certainly didn't hold back on opinions.
Far enough North of Akron AKA Krackron
What happened to him anyway .. didn't he go buy a Prius or something ?
Old 04-07-2014, 01:08 PM
  #22
Airbag's Avatar
I have had many Audis over the years .. and whenever I get weird problems like this I always find the solution in the same places..
The wiring harnesses at the flex points. My favorite is the one to the trunk that flexes when you openn and close the trunk. The wires break inside the harness and short together.
My Last Audi used to lock the trunk when i put it into reverse .. go figure
The problem will likely be the trunk Harness or the drivers side harness as they are the most used.. and remember you wont see it .. you will just have to look fo the symptoms, play with the wires and hope for the best
Old 04-07-2014, 03:05 PM
  #23
jcman's Avatar
Not sure what he is doing these days but I do remember his last thread. https://www.audiworld.com/forums/sho....php?t=2847375
Old 04-08-2014, 07:26 PM
  #24
shadowmav's Avatar
thx man I was thinkin about lookin there just havent yet
Old 04-21-2014, 01:03 PM
  #25
shadowmav's Avatar
Still cant find any broken wires. But my lumbar support isnt working either I jus noticed.
Old 04-21-2014, 01:55 PM
  #26
SloopJohnB@mac.com's Avatar
What do you mean by a ground jumper exactly. I dont wanna fry any electronics.
In the case of a short to ground I don't think it would do any good to run a ground jumper. If the code was an OPEN, then yes. In your case you need to open the harness and find the wire that is shorted to ground that should not be shorted to ground.
As to what a ground jumper is, you just take a piece of wire and connect it from the car body to the component mounting bolt…generally the component mounting bolt grounds the component to the (door or hatch) frame which is then connected to the car chassis/body that is connected to the battery negative terminal, or ground.
Old 04-21-2014, 02:14 PM
  #27
shadowmav's Avatar
ive been in and out of the harness under the driver side carpet with nothing found, ive tried playin with wires an cant find any that temp fix the problem.
Aman Singh Parhar
11-29-2016 05:03 AM
tmac2015
09-20-2015 04:29 PM
vw754
Telematics Discussion
09-20-2015 03:59 PM
2006A8LW12
09-12-2015 05:02 AM
Quick Reply: comfot control module symtoms but not it
