Driver door wiring harness replacement write-up (lots of pics)
Old 07-01-2013, 05:30 PM
  #31
B6AUDIction's Avatar
Figured it out. There's also a black clip facing you that you have to mess with after you push the purple part forward to unlock it. Thanks for the reply
Old 01-15-2016, 04:43 AM
  #32
Steven Comrie's Avatar
Default Car year
Originally Posted by x1rider
extreme cold the car has been exposed to over here. That is a good point about the fuse, would the control module fuse be found in the fusebox by the driver door? One reason I thought it might be a defective control module is the "intermittent" description found in the DTC. I'll check the fusebox nonetheless. Thanks for the advice.
What model is your Audi? I have a 2002 Audi a4 quattro 1.8t and I have the same issue and i need to order the harness. Just making sure the part number is the same. Cheers
Old 06-20-2017, 11:57 AM
  #33
alexis524's Avatar
Not to necro this thread, but, can anyone confirm whether or not the front harnesses are interchangeable between driver and passenger side?
Old 06-20-2017, 09:32 PM
  #34
shurur2's Avatar
Originally Posted by Aarononymous
I saw a similar problem on an older B6, the 2 CAN wires sheared right in the hinge area
mine too.
I just cut all the wires from the door connector and soldered in new wires.
I made a long loop like spring of my new harness inside the door, that went up into the upper door and
then traveled down. I tie wrapped it so the loop stayed sprung.
That way the wire harness is pushed back into the door when I close it and not bent each time the door is closed and the bending is spread out along the inside loop.
Old 06-21-2017, 10:16 AM
  #35
lyleswk's Avatar
Doesn't look like it but call ECS and give them your VIN.
https://www.ecstuning.com/Audi-B6_A4.../Door_Harness/
Old 06-21-2017, 12:54 PM
  #36
alexis524's Avatar
Found out that they aren't. Not trying to spend $300 on a new harness, so it looks like i'm pulling it from the door and using butt connectors to fix the 7-8 wires that are shot.
Any tips for me?
Old 06-24-2017, 08:13 PM
  #37
shurur2's Avatar
Any tips for me?
ebay has solder connectors you can hit with a heat gun.
slide the connector on, twist the wires together, center the connector on the twist and heat it....soldered connection....done.
http://www.ebay.com/itm/50pcs-Waterproof-Solder-Sleeve-Heat-Shrink-Butt-Wire-Splice-Connectors-Terminal-/262616330087
IntheQ5
Q5/SQ5 MKI (8R) Discussion
37
08-28-2023 11:37 PM
carl viking
36
04-27-2020 01:17 PM
N'Syncro
33
02-16-2020 03:12 PM
fkaufman
A7
09-07-2015 07:59 PM
Quick Reply: Driver door wiring harness replacement write-up (lots of pics)
