Driver door wiring harness replacement write-up (lots of pics)
Old 11-12-2007, 04:37 PM
  #21
x1rider's Avatar
thanks for the kind words!
Old 11-13-2007, 10:56 AM
  #22
Member
Delphingrau3003_Rich's Avatar
Default Great write-up...the question should be "Why should you even have to do this?"
what kind of crummy design would allow this to happen in the first place?
My hat is off to you, however!
Rich
Old 11-13-2007, 11:02 AM
  #23
x1rider's Avatar
Default my father (who drives a Toyota Camry with 165k miles) asked me the same thing...
He says HE never had to change a door wiring harness...
Old 11-14-2007, 03:38 AM
  #24
Member
LOL! My wife's RAV4 w/211K is the same...just noisy!
Old 11-14-2007, 11:26 PM
  #25
diagnosticator1's Avatar
Default Fuse #22 goes to the driver's door control module also, but is connected via a ...
0.5mm red/yellow wire, and provides controller power only. Fuse #37 provides power for the electric window motor, via a 2.5mm red/black wire. So, fuse 22 can be good, while fuse #37, if blown, will result in the window motor not operating. Does everything work except the window motor? If that is true, then recheck fuse #37, or check for +Vbatt at the door controller harness connector T10e, pin/terminal #6.
Old 11-15-2007, 01:28 AM
  #26
x1rider's Avatar
ok, I'll check 37
Old 04-15-2012, 01:45 PM
  #27
ruzy's Avatar
I had the same problem, I soldered the wires and it's good now; I don't know how long will it last
My problems were: 1. Dome light allways on
2. None of the power windows worked (excluding the sunroof)
3. Power mirror didn't work
4. remote didn't work with driver door
Old 06-24-2013, 11:29 AM
  #28
B6AUDIction's Avatar
How did you disconnect the plug from outlet (little purple clip in photo 19)??
Old 06-24-2013, 11:33 AM
  #29
Originally Posted by x1rider
A few weeks ago, I noticed my dome light wouldn't go off when I closed the door, also all the switches on the driver door had stopped working. After inspecting the harness where is crosses from the door jamb to the door, I noticed quite a lot of damaged wires. I ordered a replacement harness and replaced it today.
Here is the part to be replaced.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door1.jpg">
Part number for those interested.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door2.jpg">
Picture of my original switches that don't work (notice the lack of peeling, my car is a 2002).
<img src="http://i132.photobucket.com/albums/q33/x1rider/door3.jpg">
Here is a pic of why the non-peeling switches are so special!
<img src="http://i132.photobucket.com/albums/q33/x1rider/door4.jpg">
So here we go, first remove the cap under the armrest (just pry off).
<img src="http://i132.photobucket.com/albums/q33/x1rider/door6.jpg">
Remove the 2 screws seen in the hole.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door7.jpg">
With caution, unclip the door trim.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door8.jpg">
Remove the 4 screws exposed under the door trim.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door9.jpg">
Remove the screw at the bottom of the door.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door10.jpg">
This part here almost gave me a hernia. Unclip the top of the door from the edge of the window, just lift. I thought that the top part would seperate completely, it doesn't. I put a lot of effort into this before realizing that all I needed to do was unclip from the window's edge.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door11.jpg">
Now you can remove the whole inner door, before you go too far with it, unclip the door handle hook cable (seen in the center of the pic).
<img src="http://i132.photobucket.com/albums/q33/x1rider/door12.jpg">
There are 2 more connections to unplug, one to the door control module and one to the speaker, then you can completely remove the inner door. Here is a pic of the inside of the door.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door13.jpg">
Start unplugging the harness (2 connections to the door controle module and one to the speaker).
<img src="http://i132.photobucket.com/albums/q33/x1rider/door14.jpg">
Remove the plug where the harness enters the door.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door15.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/door16.jpg">
For the next part, you'll have to peel the sound insulation from the door. Remove the rectangular plug by the door handle cable.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door17.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/door18.jpg">
Unplug the connector to the latch area.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door19.jpg">
Next, unplug the connector at the door jamb (goddamn I hate those German connectors, they all seem to clip/unclip in their own little special way). In the second pic you can see the damaged wires.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door20.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/door21.jpg">
See the little black plastic thingies, make sure you push them to unclip them or you won't be able to remove the old harness.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door22.jpg">
Unclip the harness from the door.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door23.jpg">
Remove the speaker to be able to remove the old harness and thread in the new one. There are a few white plastic pins that hold the harness in place that you'll have to cut/pull off.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door24.jpg">
Before plugging everything back in, I applied dielectric grease to all the connectors.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door25.jpg">
You can now insert the new harness (start at the door, obviously). Everything is just the reverse of the removal, make sure you insert the black and white plastic thingies in the holes so that the new harness doesn't rattle around.
Before re-installing the inner door, I tried the switches, they don't friggin' work, goddamn. A Vag-Com scan revealed the following DTC.
Address 09: Cent. Elect.
Control Module Part Number: 8E0 907 279 E
Component and/or Version: int. Lastmodul KAN 0305
Software Coding: 00014
Work Shop Code: WSC 63351
1 Fault Found:
01331 - Door Control Module; Driver Side (J386)
49-10 - No Communications - Intermittent
I guess I'll have to replace the door control module.
<img src="http://i132.photobucket.com/albums/q33/x1rider/door26.jpg">
Oh well, it's not like I replaced the harness for nothing, the damage was pretty easy to see (the new harness didn't cause a speaker connection DTC to appear and the driver door speaker works now).
I'll drive a la Jet Jockey (no inner door) until the new door controle module arrives I guess.
How did you unplug the connecter in photo 19 (little purple clip thingy)??
Old 06-25-2013, 02:23 PM
  #30
lyleswk's Avatar
Should be a simple gentle push pull on the purple part by hand. I don't remember these being tricky.
Quick Reply: Driver door wiring harness replacement write-up (lots of pics)
