SQ5 TDI Exhaust Sound Booster
Old 01-23-2014, 12:28 PM
AudiQ5sleeper's Avatar
Originally Posted by Transfer
Say what now? A speaker in the exhaust sounds very incorrect. Maybe the TDI is diferent from the TFSI but I thought the actuators just opened up the shutoff valves of inner tail pipes, allowing exhaust to flow out of all 4 exits vs 2 when actuators are closed. More exhaust openings = more loud.
So what is the "actuator"?
I want more volume out of my TFSI so that's why I'm curious.
an actuator is a module similar to a throttle body for intake. When the gas pedal is pressed. it would flip open to allow more exhaust out to create additional "roar" to the exhaust.
something like this
http://www.spracingonline.com/upload...file=sp3in.jpg
Old 01-23-2014, 01:03 PM
Transfer's Avatar
Originally Posted by josedebardi
TDI has 2 speakers (aka sound actuators), one in each back box.
http://www.audi.co.uk/new-cars/q5/sq...-actuator.html
I was under the impression the TFSI had a similar setup, but I do know it has butterflies in the pipes so your analysis may be accurate.
Here is a photo I took when I had my bumper off to install a hitch.
It shows the "actuator" which I had thought only contolled the valve flap directly beneath it in the exhaust tip (easily seen if you look inside the exhaust tip). Are there any active sound pulses coming from this thing as well? I'll have to inspect the exhaust pipe closer.
Old 01-23-2014, 01:13 PM
josedebardi's Avatar
Here is a photo I took when I had my bumper off to install a hitch. It shows the "actuator" which I had thought only contolled the valve flap directly beneath it in the exhaust tip (easily seen if you look inside the exhaust tip). Are there any active sound pulses coming from this thing as well? I'll have to inspect the exhaust pipe closer.
Looks quite different from the TDI version;
http://www.myaudiq5.com/index.php/to...the-bottom-up/
Pretty sure yours is just a flap, or at least the bit pictured is.
Old 01-23-2014, 01:34 PM
spijun's Avatar
This is actuator for impact sound
Old 01-23-2014, 01:44 PM
spijun's Avatar
Do not trust what it says on the website audi.co.uk
There exists a lot of nonsense.
Old 01-23-2014, 01:48 PM
Originally Posted by spijun
Do not trust what it says on the website audi.co.uk There exists a lot of nonsense.
You are confusing this post with irrelevant information.
In this case the Audi UK site is correct in its description of the SQ5 TDI exhaust...
Old 01-23-2014, 01:53 PM
spijun's Avatar
Yes exactly the same as this
or
two amplifiers for the B & O system or 300 mm disc brakes on SQ5
Old 01-23-2014, 03:21 PM
  #18
Transfer's Avatar
Interesting. That is definitely different. Now I have to figure out how to make my exhaust louder when valves are open, or at least modify to keep them open all the time. Why would I want them closed? It's not that loud anyway.
Old 01-23-2014, 07:19 PM
  #19
Club AutoUnion
scrmorling's Avatar
I believe the exhaust valves will be open all the time you're driving in S mode. I just wish we could set the car to start in S not in D. Steve
Old 01-23-2014, 11:22 PM
  #20
Automotive Systems Cete's Avatar
@Transfer:
That is the Actuator for "inside" Sound...
The TDI Exhaust has got one "another" actuator for each silencer.
BR
Quick Reply: SQ5 TDI Exhaust Sound Booster
