Removing rear head restraints on 2014 Q5
Old 10-06-2013, 05:23 PM
  #21
soonerfan's Avatar
Amen. All of this is making my neck hurt.
Old 10-02-2018, 02:22 PM
  #22
a1sailor's Avatar
Originally Posted by robodoc
Agree, it's strayed off topic. That said, I saw nothing condescending in NABS4's suggestions.
In summary, the rear headrests can be removed if desired be to accommodate a child's car seat, luggage, etc, but it requires some fiddling as described in spijun's reply to my original post. It can be done, however, without any fancy tool--it just requires something firm that can slipped under the plastic "cap" of the left pillar (when facing the seat) of the head restraint. And the seat release needs to be pulled so the seat can angle forward to allow the headrest to clear the roof.
I had the same issue on a 2015 removing rear head rests to fold rear seats and have sufficient leg room in the front- below is picture and instructions from the manual to remove rear head rests. It suggests using the metal key but I used a plastic screw driver to avoid damage to seat fabric. There is a small plastic tab location under the trim ring that needs to be pushed in towards the head rest post.
location to insert tool to remove rear head rest.
Instructions from owners manual for rear head rest removal.
Old 12-01-2018, 08:49 AM
  #23
tipster1947's Avatar
THANK YOU!!!!!
Old 06-28-2020, 06:25 AM
  #24
Lmk
Lmk's Avatar
Default Audi q3 2011 rear headrest removal
Just trying to fit a child seat in my mum's 2011 q3 and after much swearing we figured out that by putting a small electricians screwdriver into the hole in the inside of the left collar you can release the post. It took some doing but you can feel the spring loaded catch inside if you push something small in.
There's a small hole on the inside of other collar awqy from the one you use to release or reposition the headrest.
Old 06-28-2020, 11:07 AM
  #25
spijun's Avatar
Wrong place, this is a forum for Q5, not for Q3
FYI these are different systems
xkahn
02-08-2018 10:43 AM
ohsigmachi
03-29-2016 05:04 AM
S4intheOC
09-08-2015 12:12 AM
bebopdeluxe
A6 (C7 Platform) Discussion
09-05-2015 04:11 PM
tripevans
A4 (B7 Platform) Discussion
09-05-2015 11:55 AM
Quick Reply: Removing rear head restraints on 2014 Q5
