New Spacers
Old 04-23-2013, 03:58 PM
///M Traitor's Avatar
Originally Posted by Harsany
The car came with Bridgestones Potenzas Pole position S04. I'll take some better pics
I really wonder if that makes a difference. I do have the Pirelli's and they are "funny". The rim is actually wider than the contact patch (and consequently the portion of the tire that is nearest to the fender). When I look at the offset with the 12/15 setup, I feel like the rim is perfect, but the top of the tire is in another 1/2" from the rim which makes it look further in. I hope you follow what I'm trying to say. I'll post some hi-rez pics when I get around to cleaning the car and taking them.
Old 04-24-2013, 06:57 AM
GiantEli's Avatar
I have some 15mm and 8mm spacers from my S4 that I'm going to try. I also happen to have some 20mm and 5mm from the same car, but those seem out of line here.
I have the Pirelli's as well, and what I believe you're referring to is the "stretching" of the tire on the wheel. The math should be such that the 255mm wide tire sits just wider than the wheel, which at 8.5" is 216mm wide, or 40mm narrower than the widest point on the tire, which isn't the contact patch. So, two things at play...(1) the cross section on the Pirelli's has a severe curve to it and/or (2) you don't have 255s on your car. I believe the former.
It seems that all the performance setups on the B8/C7 models are gravitating around the same 19x8.5 + 255/35 setup. Aside from scale economies (if I see those split 5-spoke 18s (s4) and 19s (s6) and 20s (s8) again, I might plotz), there can't be a great reason for all the overlap, aesthetically.
Old 04-24-2013, 08:30 AM
Harsany's Avatar
Here are some pics of 12MM front and 15MM rear spacers
Old 04-24-2013, 08:51 AM
Delurker's Avatar
Thanks for those pics! That looks really nice and just right to me.
Old 04-24-2013, 09:28 AM
Harsany's Avatar
No problem. The pics don't do any justice. It looks way better than the factory stance. The car looks alot more aggressive.
Old 04-25-2013, 06:26 PM
dtothedtotheo's Avatar
any vibrations?
Old 04-25-2013, 07:58 PM
Harsany's Avatar
No way, not with H & R spacers, perfect fit.
Old 04-25-2013, 10:36 PM
  #18
arjanh's Avatar
I feel vibrations when braking from high speed with h&r's (12 mm front and 15 mm rear)
I removed the fronts and vibrations are gone.
Old 04-26-2013, 05:13 AM
  #19
GiantEli's Avatar
This happened on the S4s as well...i think with 10mm though.
Old 04-26-2013, 05:33 AM
  #20
Harsany's Avatar
You had vibrations on other cars, how is that relevant? If dont have the spacers properly fitted with proper lugs, who knows what you would get. There is no vibration at any speed or braking. Actually, I have a spacers on all of my cars, and never had a problem.
The fitment of these spacers on the hub and the wheel is just perfect.
Quick Reply: New Spacers
