Q7 replacing your rear brake pads write up
Old 05-17-2010, 08:44 AM
OilBurner's Avatar
Originally Posted by IsR
Where in Florida is best to get the pads?
I ordered all of my parts on-line. Used PartsTrain.com for the sensors and BuyBrakes.com for the pads. There are other vendors on this site that sell pads and sensors. I have used these two in the past and have had good luck.
Old 05-18-2010, 12:30 PM
IsR
IsR's Avatar
Thanks!
Old 05-18-2010, 01:17 PM
sealf76's Avatar
if you spray some WD-40 on these sonsors, you can save them....istead pray off...with some grease...it just slip came out of it. that's my experience.
Old 04-04-2012, 07:13 PM
ausold's Avatar
Hi
Did you get the chance to post instruction for the front brake on your Q7 ?
cheers
Old 04-07-2012, 01:44 PM
markcorrado1's Avatar
Originally Posted by ausold
Hi
cheers
I just did the fronts 2 weeks ago, here's a link to my post which includes a youtube video from a VW Touareg:
https://www.audiworld.com/forums/sho....php?t=2824143
MAKE SURE you get some PB Blast and soak the caliper to carrier bolts!!! It took every bit of my strength to bust the bolts on the drivers side and I'm a fit 240lbs guy
Some other pointers, make sure you have a tq wrench that can tq to at least 200lbs, PB Blast is your friend, buy new bolts for the caliper to carrier, especially for the rear as I have read the rear triple square bolts are stretch bolts and new screws for the rotors... Have a impact screw driver to remove the rotor screws...
If you like to work on German cars a lot, I also found this triple square set for a decent price, it's made by Canadian tool company Genius
http://www.geniustools.net/products/...?item=BS-3416M
I got mine from this company: http://www.mltoolsequipment.com/product_p/bs-3416m.htm
Old 08-22-2013, 09:17 AM
kkkkk's Avatar
Default Changing break pads on the Q7
I have two videos on Vimeo on how to change break pads
Old 08-22-2013, 09:21 AM
kkkkk's Avatar
Default Changing front disc Pads on Q7
Changing Back Break Pass On A Audi Q7 on Vimeo
This is the video on changing the front disc pads
sh1kaladka
27
07-08-2023 11:54 PM
A8Pete
13
01-11-2014 02:57 AM
Pope
05-23-2011 01:31 AM
W Alan
Audi allroad
16
03-27-2009 09:16 AM
SNAFU 4
09-28-2006 05:50 PM
Quick Reply: Q7 replacing your rear brake pads write up
