PURE Motorsport | Go Fast Bits DV+
Old 01-03-2014, 10:02 AM
Former Vendor
andrew@purems's Avatar
Default PURE Motorsport | Go Fast Bits DV+
Introducing the new DV+ for late-model VAG and Euro applications!
GFB’s DV+ solution couldn’t be simpler - keep what works and replace what doesn’t.
Worldwide Patent and Design Patent Pending
* Retains the factory solenoid coil for seamless integration
* Replaces plastic valve parts with metal for reliability and strength on chipped engines
* Direct-fit replacement with GFB’s TMS benefits
* Exclusive “pilot-actuated” valve mechanism for rapid response at high boost
GFB expands the DV+ range with a direct-fit solution for the weak factory diverter valve used on many European vehicles.
The solenoid coil itself from the factory-fitted valve is great (the ECU opens it faster than any pneumatic valve so why replace it?), but the weak point however is the valve mechanism itself. So GFB’s DV+ solves this problem by replacing just the valve parts with an anodized billet aluminum housing fitted with a brass piston machined to exacting tolerances.
The end result is sharper throttle response, lightning-fast valve actuation, and it will hold as much boost as you can throw at it.
Other manufacturers’ products involve replacing the entire system with a traditional pneumatic valve, requiring long vacuum hose runs, additional parts for tapping into the intake manifold vacuum, plus either a different solenoid valve to actuate the pneumatic valve or a ballast resistor to plug into the OE wiring loom. All these additional items result in a product that is slower, less responsive, more expensive and takes much longer to install.
GFB’s DV+ solution on the other hand is more responsive, less expensive, easier to install, and doesn’t cause compressor surge/turbo flutter. Oh, and it doesn’t require different springs or frequent re-builds.
The DV+ story: Better performance - more reliable
Order Here!
Old 01-09-2014, 08:34 AM
Former Vendor
Plenty of these in in stock, get yours today!
Old 01-14-2014, 09:05 AM
Former Vendor
In stock and ready to go!
Old 04-15-2014, 09:28 AM
Former Vendor
Order here!
Quick Cal
4.2 V8 Discussion
06-25-2018 07:57 AM
balabee
TT (Mk1) Discussion
12-26-2015 08:23 AM
smallbizwhiz
S4 (B8 Platform) Discussion
09-24-2015 11:31 AM
Quick Reply: PURE Motorsport | Go Fast Bits DV+
