Red iPod Cable Information
Old 05-06-2012, 04:05 AM
  #51
DirkM's Avatar
Originally Posted by ishh
Whether the playback of videos are from USB, MMC, or the built-in HDD, all u have to do is convert the video to the specified file type and the maximum frame rate indicated in the user manual under the multimedia section.
I also had to change the size, I couldn't play any of my "HD" movies (480p and above). Anything up to 400 pixel high played fine.
Old 05-06-2012, 11:08 AM
  #52
joseaudi's Avatar
Default Anyone heard about an update for early models
I want the album art and am waiting for any option to get this
Old 05-06-2012, 01:22 PM
  #53
ishh's Avatar
Originally Posted by Mickelin
Problem is, my manual doesn't specify any file format specs for video, only for audio. Could you please post the video specs from your manual? Thx
Video:
.mp4 .m4v .mov .avi (divx/xvid) .mpg .mpeg .wmv .asf
Max 2000kbps, 576x720 pixel (or vice versa), 25fps.
Audio:
.mp3 .m4a .m4b .aac .wma .asf
Max 320kbps, 48kh.
Good luck..
Old 05-06-2012, 01:31 PM
  #54
ishh's Avatar
Album art works with the SD card and the built in HDD with a maximum resolution of 800x800p. The red cable does the job too.
Old 05-06-2012, 04:34 PM
  #55
manishaudi's Avatar
What version is your MMI?
Old 05-06-2012, 09:43 PM
  #56
kundu's Avatar
Any idea if this works with version PO485 of MMI?
Old 05-06-2012, 10:08 PM
  #57
joseaudi's Avatar
I know about the hdd, who wants to load their entire iTunes library into the hard drive ? Not me. I want the new software since I was one of the first a6 's on the road.
Old 05-07-2012, 06:56 AM
  #58
gb4.2's Avatar
I'm from the D4 A8/A8L forum and am not able to view the album cover art when using the red grommet AMI cable attached to my iPhone 4S and I have what I believe is the latest MMI software version: HN+R_US_AU_P0487
My vehicle (2012 A8L) was built in February and I've had it for 3 weeks.
I also tried two other new Audis at my dealer, a 2012 A8L built in Dec, 2011 and a 2012 A7 built in Jan., 2012. Both have the same MMI software version as mine. Neither of them showed album cover art.
Is there a "trick" to getting this to work? I just read this entire thread and it would seem I have the correct MMI software version. I haven't tried the power down/power up of my iPhone yet (as was discussed in this thread) but I'll try it today.
You'd think this would be a simple "plug 'n' play" feature but it seems to work for some and not for others.
One other question---If I load my music library to an SD card, is there a way to transfer the album art to the card as well so that it shows up on the MMI screen? I'd rather just use the cable but a workaround could be the SD card.
Any/all help is appreciated.
Old 05-07-2012, 01:05 PM
  #59
Stevial's Avatar
Should work for that software version yes.
Old 05-07-2012, 01:36 PM
  #60
Stevial's Avatar
your software should does support the cable. If it didn't you would get an error message that the cable isnt supported, or you would see an unsupported cable message.
try Powering off you iPhone and powering it back on again and try connecting it again.
Also try going into settings and see if track info is checked.
Quick Reply: Red iPod Cable Information
