Frequently Asked Questions and Common Problems Thread Collection
Old 04-23-2006, 05:17 AM
  #181
MarTT's Avatar
Default Using Techron to repair fuel gauge / fuel sending units . . .
Known issue with fuel sending units causing fuel gauge to read erratically (often mis-diagnosed as a faulty guage cluster) can be repaired with a couple tanks of Techron. See link below from Chevron's site. More involved fix for faulty fuel guage/faulty fuel sending units is to clean them using RoberTT's fotki write-up (see post above).<ul><li><a href="http://www.chevron.com/products/prodserv/fuels/additives/concentrate_plus.shtml">http://www.chevron.com/products/prodserv/fuels/additives/concentrate_plus.shtml</a</li></ul>
Old 04-30-2006, 03:11 PM
  #182
MarTT's Avatar
Default Belly pan repair parts . . .
See link below.<ul><li><a href="https://forums.audiworld.com/tt/msgs/1484922.phtml">Belly pan repair part numbers</a></li></ul>
Old 05-06-2006, 06:57 AM
  #183
blackfnTTruck's Avatar
Default Coil Pack replacement, push in type...
<ul><li><a href="http://public.fotki.com/blackfnTTruck/coil_pack_replacement/">Coil Pack</a></li></ul>
Old 05-06-2006, 04:02 PM
  #184
aviattor.3's Avatar
How about for the belly pan itself?
Old 05-06-2006, 04:10 PM
  #185
MarTT's Avatar
Default Belly pan is 8N0 825 235 F - - original post updated -
Please delete your post above to clean up the thread.
Old 05-07-2006, 08:07 PM
  #186
specialidiot's Avatar
Bookmarks
  #187
Default my bookmark files
<ul><li><a href="http://www.specialidiot.net/03225qc/ttbookmarks1.html">tt bookmarks</a></li></ul>
Old 05-10-2006, 08:58 PM
  #188
MCPaudiTT - DEFCON 1's Avatar
Default Cluster Repair Contact
<a href="https://forums.audiworld.com/tt/msgs/1480881.phtml"> From this thread</a><ul><li><a href="http://www.bba-reman.com/content.aspx?content=hints_and_tips">Look under "Audi" at this link</a></li></ul>
Old 05-10-2006, 09:10 PM
  #189
Elder Member
meem's Avatar
Default defeating airbag light with aftermaket front seats
if you install aftermarket seats, you will need to use some resistors in order to get the airbag light to turn off. in particular:
1. a 4.7 ohm resistor is needed across the two populated pins of the airbag connector (purple + yellow) on both seats.
2. if you do not reuse the stock seatbelt buckles, a 400-500 ohm resistor is need across two of the pins on the red connector on both seats. (i cannot recall which pins, but if you examine the passenger-side's red connector, you will observe only two pins are populated; use the same two pins on the driver's side).
in all cases, 1/2 watt resistors will be fine.
note that if your airbag light is already on, you will need to clear the codes in order to get the airbag light to turn off.
Old 06-12-2006, 04:04 PM
  #190
MaxHedrm's Avatar
Default Entire list (I think)
Stolen from Osram/Sylvania's site [my additions in brackets]:
2001 AUDI TT (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
H7
Rear turn signal
7506
Tail light
7528 [<a href="http://www.donsbulbs.com/cgi-bin/r/b.pl/p21%7c5w.html">P21-5W</a> (from the housing) / <a href="http://www.donsbulbs.com/cgi-bin/r/b.pl/1157.html">1157</a>]
Stop light
High mount stop light
%COM
Fog/Driving light
H3-55W
License plate
6418
Back up light
7506 [<a href="http://www.donsbulbs.com/cgi-bin/r/b.pl/p21w.html">P21W</a>]
Rear sidemarker
2825
Glove box
2821
Map light
64111
Dome light
6411
Step/Courtesy light
6418
Trunk/Cargo area
2825
2001 AUDI TT (With replaceable halogen capsules)
Low beam headlamp
H1-55W
Also a handy link to look up compatible bulbs:
<a href="http://www.donsbulbs.com/">Don's Bulbs</a>
I'll try to come back &amp; add more detail occasionally as I replace more bulbs. :^)
Quick Reply: Frequently Asked Questions and Common Problems Thread Collection
