Frequently Asked Questions and Common Problems Thread Collection
Old 01-14-2006, 09:07 AM
  #151
nikhil's Avatar
h&r:
  #152
nikhil's Avatar
bilstein pss/pss9:
Old 01-14-2006, 09:12 AM
  #153
StartXJeff's Avatar
Default Front parking and turn lamp #'s
Front Parking Lamp Replacements
The front parking lamp uses a H6W (ECE nomenclature) bulb. This is a 12V, 6W halogen bulb with a BAX9S base. Manufacturer numbers include Osram 64132, Philips 12357, Philips 12357LL (long life), Narva 68161, and Narva 68162 (long life). The VW/Audi p/n is N 104 455 02.
The front turn signal lamp uses an H21W bulb. This is a 12V, 21W bulb with a BAY9S base. Manufacturer numbers include Osram 64132, Philips 12357, Philips 12357LL, Narva 68161, Narva 68162 (LL). VW/Audi N 104 456 01.
http://www.1stvwparts.com/ $7.84 + min $7.50 shipping charge.
You might as well go to a dealer.
Dealer MSRP = $10.50
Old 01-14-2006, 09:15 AM
  #154
TTinWV's Avatar
Default H&R 21 mm Adjustable Rear Sway Bar Installation
Here's a write up of my H&amp;R 21 mm Adjustable Rear Sway Bar installation. Hope that someone finds it useful.<ul><li><a href="http://www.blackwood-wv.net/TTinWV/mods.htm#H&amp;R%2021%20mm%20Adjustable%20Rear%20S way%20Bar%20-%2014%20January%202006">H&amp;R 21 mm Adjustable Rear Sway Bar Installation</a></li></ul>
Old 01-14-2006, 10:31 AM
  #155
erikazra's Avatar
Default Re: You can get a system deodorizer that sprays into the vent intake.
should i spray the cabin filter with a fabreeze or in the a/c vent?
Old 01-14-2006, 10:33 AM
  #156
erikazra's Avatar
btw i think the smell came when i put in the new cabin filter (from audi's parts dept. not 3rd party)
Old 01-15-2006, 01:38 PM
  #157
MCPaudiTT - DEFCON 1's Avatar
Default Accessing tail light module and bulbs:
There are two thumb screws behind an access panel:
<img src="http://images7.fotki.com/v142/photos/4/435091/1708675/DSC00073-vi.jpg">
With those out (and the electrical connection freed), the whole assembly pulls straight out.
With the rear "circuit" panel removed (just a few screws) all the bulbs are easily accessible:
<img src="http://images14.fotki.com/v221/photos/4/435091/2676996/02USStyleCircuitRemoval-vi.jpg"><ul><li><a href="http://public.fotki.com/mcphill/audi_stuff/lighting_systems/uk_drivers_tail_light/dsc00073.html">http://public.fotki.com/mcphill/audi_stuff/lighting_systems/uk_drivers_tail_light/dsc00073.html</a</li></ul>
Old 01-15-2006, 05:34 PM
  #158
SparTTan's Avatar
Default I wouldn't spray anything directly onto the filter, especially Fabreeze
If you are going to spray something somewhere, make sure it is a quality system deodorizer made specifically for automotive HVAC systems and you apply it per the manufacturer's instuctions.
Old 01-19-2006, 12:09 PM
  #159
AudiWorld Uber User
TTschwing's Avatar
Default Headlight Tab repair kit part # 8N0 998 121
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1425912.phtml">https://forums.audiworld.com/tt/msgs/1425912.phtml</a</li></ul>
Old 01-21-2006, 05:13 AM
  #160
StartXJeff's Avatar
Default AUDI DIAGNOSTIC TROUBLE CODE (DTC) OVERVIEW
The Diagnostic Trouble Code (DTC) overview is organized according to VAG and SAE (OBD-II) trouble
codes.
MIL Switching Conditions
A=MIL Triggered on first occurrence
B=MIL Triggered on second occurrence
C=Non Emission related Fault - Service light only
D=Non Emission Fault - No warning light
DTC (VAG) DTC (SAE) MALFUNCTION TEXT (Component Number) MIL CONDITION
16485 P0101 Mass or Volume Air Flow Circuit - Range/Performance A
16486 P0102 Mass or Volume Air Flow Circuit - Low input A
16487 P0103 Mass or Volume Air Flow Circuit - High Input. May be due to a low battery if found with
17988 (P1580) A
16496 P0112 IAT Sensor - Temp High - Circuit Low - G42 A
16497 P0113 IAT Sensor - Temp Low - Circuit High - G42 A
16500 P0116 Engine Coolant Temperature Circuit - Range/Performance Problem A
16501 P0117 Engine Coolant Temperature Circuit - Low Input (High Temp) A
16502 P0118 Engine Coolant Temperature Circuit - High Input (Low Temp) A
16504 P0120 Throttle Position Sensor A - Circuit Malfunction A
16505 P0121 Throttle Position Sensor A - Circuit - Performance Problem - Out of Range A
16506 P0122 Throttle Position Sensor A Circuit - Low Voltage Input A
16507 P0123 Throttle Position Sensor A Circuit - High Voltage Input A
16509 P0125 Cooling System - Temp Too Low to Enter Closed Loop - G62 B
16514 P0130 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 1) A
16515 P0131 O2 Sensor Circuit - Voltage Low (Bank 1 Sensor 1) B
16516 P0132 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 1) A
16517 P0133 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 1) B
16518 P0134 O2 Sensor Circuit - No Activity Detected (Bank 1 Sensor 1) A
16519 P0135 O2 Sensor Heater Circuit - Malfunction (Bank 1 Sensor 1) A
16520 P0136 O2 Sensor Circuit - Malfunction (Bank 1 Sensor 2) A
16521 P0137 O2 Sensor Circuit - Low Voltage (Bank 1 Sensor 2) B
16522 P0138 O2 Sensor Circuit - High Voltage (Bank 1 Sensor 2) A
16524 P0140 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 2) B
16525 P0141 O2 Sensor Heater Circuit - Malfunction (Bank 1 Sensor 2) A
16534 P0150 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 1) A
16536 P0152 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 1) A
16537 P0153 O2 Sensor Circuit - Slow Response (Bank 2 Sensor 1)
16538 P0154 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 1) A
16539 P0155 O2 Sensor Heater Circuit - Malfunction (Bank 2 Sensor 1) A
16540 P0156 O2 Sensor Circuit - Malfunction (Bank 2 Sensor 2) A
16542 P0158 O2 Sensor Circuit - High Voltage (Bank 2 Sensor 2) A
16543 P0159 O2 Sensor Circuit - Slow Response (Bank 2 Sensor 2)
16544 P0160 O2 Sensor Circuit - No Activity Detected (Bank 2 Sensor 2) A
16545 P0161 O2 Sensor Heater Circuit - Malfunction (Bank 2 Sensor 2) A
16554 P0170 Fuel Trim - Malfunction (Bank 1) A
16555 P0171 Fuel Trim - System Lean (Bank 1) B
16556 P0172 Fuel Trim - System Rich (Bank 1) B
16557 P0173 Fuel Trim - Malfunction (Bank 2) B
16558 P0174 Fuel Trim - System Lean (Bank 2) B
16559 P0175 Fuel Trim - System Rich (Bank 2) B
16684 P0300 Random Misfire Detected - Any Cylinder B
16685 P0301 Cylinder #1 - Misfire Detected A or B / Blink
16686 P0302 Cylinder #2 - Misfire Detected A or B / Blink
16687 P0303 Cylinder #3 - Misfire Detected A or B / Blink
16688 P0304 Cylinder #4 - Misfire Detected A or B / Blink
16689 P0305 Cylinder #5 - Misfire Detected A or B / Blink
16690 P0306 Cylinder #6 - Misfire Detected A or B / Blink
16691 P0307 Cylinder #7 - Misfire Detected A or B / Blink
16692 P0308 Cylinder #8 - Misfire Detected A or B / Blink
16706 P0322 Ignition/Distributor Engine Speed Input Circuit - No Signal A or B / Blink
16711 P0327 Knock Sensor #1 Circuit - Low Input (Bank 1 or Single Sensor) A
16716 P0332 Knock Sensor #2 Circuit - Low Input (Bank 2) A
16721 P0337 Crankshaft Position Sensor Circuit - Low Input A
16725 P0341 Camshaft Position Sensor Circuit - Out of Range/Performance A
16784 P0400 Exhaust Gas Recirculation (EGR) - Flow Malfunction B
16785 P0401 Exhaust Gas Recirculation (EGR) - Flow Insufficient B
16786 P0402 Exhaust Gas Recirculation (EGR) - Flow Excessive B
16795 P0411 Secondary Air Injection System (B2) - Incorrect Flow B
16806 P0422 Main Catalyst Efficiency - Below Threshold (Bank 1) B
16816 P0432 Main Catalyst Efficiency - Below Threshold (Bank 2) B
16824 P0440 Evaporative Emission Control System (EVAP) - Purge Malfunction B
16825 P0441 Evaporative Emission Control System - Incorrect Purge Flow A
16826 P0442 Evaporative Emission Control System - Leak Detected (small leak) B
16836 P0452 Evaporative Emission Control System - Pressure Sensor - Low Input B
16837 P0453 Evaporative Emission Control System - Pressure Sensor - High Input
16839 P0455 Evaporative Emission Control System - Leak Detected (gross leak)
16845 P0461 Fuel Level Sensor Circuit - Range/Performance B
16885 P0501 Vehicle Speed Sensor - Range/Performance A
16890 P0506 Idle Control Module - RPM Lower Than Expected A
16891 P0507 Idle Control Module - RPM Higher Than Expected A
16894 P0510 Throttle Position Sensor - Closed Switch B
16989 P0605 Internal Control Module Read Only Memory (EPROM) Error B
17090 P0706 Transmission Range Sensor Circuit - Range/Performance A
17091 P0707 Transmission Range Sensor Circuit - Low Input D
17509 P1101 O2 Sensor Circuit (B1-S1) Voltage Too Low/Air Leak D
17510 P1102 O2 Sensor Circuit Heating Circuit (B1-S1) - Short to B+ A
17511 P1103 O2 Sensor Circuit Heating Circuit (B1-S1) - Output Too Low A
17512 P1104 O2 Sensor Circuit (B1-S2) Voltage Too Low - Air Leak A
17513 P1105 O2 Sensor Circuit Heating Circuit (B1-S2) -Short to B+ A
17514 P1106 O2 Sensor Circuit (B2-S1) Voltage Too Low - Air Leak A
17515 P1107 O2 Sensor Circuit Heating Circuit (B2-S1) - Short to B+ A
17516 P1108 O2 Sensor Circuit Heating Circuit (B2-S1) - Output too Low A
17517 P1109 O2 Sensor Circuit (B2-S2) Voltage Too Low - Air Leak A
17518 P1110 O2 Sensor Circuit Heating Circuit (B2-S2) - Short to B+ A
17535 P1127 Long Term Fuel Trim - System too Rich (Bank 1) A
17536 P1128 Long Term Fuel Trim - System too Lean (Bank 1) B
17609 P1201 Cylinder #1 Fuel Injector Circuit - Electrical Malfunction B
17610 P1202 Cylinder #2 Fuel Injector Circuit - Electrical Malfunction A
17611 P1203 Cylinder #3 Fuel Injector Circuit - Electrical Malfunction A
17612 P1204 Cylinder #4 Fuel Injector Circuit - Electrical Malfunction A
17613 P1205 Cylinder #5 Fuel Injector Circuit - Electrical Malfunction A
17614 P1206 Cylinder #6 Fuel Injector Circuit - Electrical Malfunction A
17615 P1207 Cylinder #7 Fuel Injector Circuit - Electrical Malfunction A
17616 P1208 Cylinder #8 Fuel Injector Circuit - Electrical Malfunction A
17621 P1213 Cylinder #1 Fuel Injector Circuit - Short to B+ A
17622 P1214 Cylinder #2 Fuel Injector Circuit - Short to B+ A
17623 P1215 Cylinder #3 Fuel Injector Circuit - Short to B+ A
17624 P1216 Cylinder #4 Fuel Injector Circuit - Short to B+ A
17625 P1217 Cylinder #5 Fuel Injector Circuit - Short to B+ A
17626 P1218 Cylinder #6 Fuel Injector Circuit - Shod to B+ A
17627 P1219 Cylinder #7 Fuel Injector Circuit - Shod to B+ A
17628 P1220 Cylinder #8 Fuel Injector Circuit - Shod to B+ A
17633 P1225 Cylinder #1 Fuel Injector Circuit - Short to Ground A
17634 P1226 Cylinder #2 Fuel Injector Circuit - Short to Ground A
17635 P1227 Cylinder #3 Fuel Injector Circuit - Short to Ground A
17636 P1228 Cylinder #4 Fuel Injector Circuit - Short to Ground A
17637 P1229 Cylinder #5 Fuel Injector Circuit - Short to Ground A
17638 P1230 Cylinder #6 Fuel Injector Circuit - Short to Ground A
17639 P1231 Cylinder #7 Fuel Injector Circuit - Short to Ground A
17640 P1232 Cylinder #8 Fuel Injector Circuit - Short to Ground A
17645 P1237 Cylinder #1 Fuel Injector Circuit - Open Circuit A
17646 P1238 Cylinder #2 Fuel Injector Circuit - Open Circuit A
17647 P1239 Cylinder #3 Fuel Injector Circuit - Open Circuit A
17648 P1240 Cylinder #4 Fuel Injector Circuit - Open Circuit A
17649 P1241 Cylinder #5 Fuel Injector Circuit - Open Circuit A
17650 P1242 Cylinder #6 Fuel Injector Circuit - Open Circuit A
17651 P1243 Cylinder #7 Fuel Injector Circuit - Open Circuit A
17652 P1244 Cylinder #8 Fuel Injector Circuit - Open Circuit A
17656 P1250 Fuel Level Too Low A
17733 P1325 Cylinder #1 Knock Control Limit Attained D
17734 P1326 Cylinder #2 Knock Control Limit Attained D
17735 P1327 Cylinder #3 Knock Control Limit Attained D
17736 P1328 Cylinder #4 Knock Control Limit Attained D
17737 P1329 Cylinder #5 Knock Control Limit Attained D
17738 P1330 Cylinder #6 Knock Control Limit Attained D
17739 P1331 Cylinder #7 Knock Control Limit Attained D
17740 P1332 Cylinder #8 Knock Control Limit Attained D
17747 P1339 Crankshaft Position/Engine Speed Sensors Cross connected D
17748 P1340 Camshaft/Crankshaft Position Sensors (B2) - Out of Sequence A
17749 P1341 Ignition Coil Power Output Stage #1 - Short to Ground A
17751 P1343 Ignition Coil Power Output Stage #2 - Short to Ground A
17753 P1345 Ignition Coil Power Output Stage #3 - Short to Ground A
17799 P1391 Camshaft Position Sensor (B2) - Short to Ground A
17800 P1392 Camshaft Position Sensor Open (B2) - Short to B+ A
17801 P1393 Ignition Coil Power Output Stage #1 - Electrical Malfunction A
17802 P1394 Ignition Coil Power Output Stage #2 - Electrical Malfunction A
17803 P1395 Ignition Coil Power Output Stage #3 - Electrical Malfunction A
17804 P1396 Engine Speed Sensor - Missing Tooth A
17808 P1400 EGR Valve Circuit - Electrical Malfunction A
17809 P1401 EGR Valve Circuit - Power Stage Short to Ground A
17810 P1402 EGR Valve Circuit - Short to B+ A
17815 P1407 EGR Temperature Sensor - Signal too Low A
17816 P1408 EGR Temperature Sensor - Signal too High B
17817 P1409 Tank Ventilation Valve - Electrical Malfunction B
17818 P1410 Tank Ventilation Valve - Short to B+ A
17819 P1411 Secondary Air Injection System (B2) - Restricted Flow A
17822 P1414 Secondary Air Injection System (B2) - Leak Detected B
17826 P1418 Fuel Level Sensor - Signal too High B
17828 P1420 Secondary Air Injection System Control Module - Electrical Malfunction
17829 P1421 Secondary Air Injection System Control Valve Circuit - Short to Ground A
17830 P1422 Secondary Air Injection System Control Valve Circuit - Short to B+ A
17831 P1423 Secondary Air Injection System (B1) - Flow too Low A
17832 P1424 Secondary Air Injection System (B1) - Leak Detected B
17833 P1425 Tank Ventilation Valve - Short to Ground A
17834 P1426 Tank Ventilation Valve - Open Circuit A
17842 P1434 Secondary Air Injection System Pump Relay Circuit - Short to B+ A
17844 P1436 Secondary Air Injection System Pump Relay Circuit - Electrical Malfunction A
17848 P1440 EGR Valve Circuit - Power Stage Open A
17858 P1450 Secondary Air Injection System Pump Relay Circuit - Short to B+ A
17859 P1451 Secondary Air Injection System Pump Relay Circuit - Short to Ground A
17860 P1452 Secondary Air Injection System Pump Relay Circuit - Open Circuit A
17878 P1470 EVAP Emission Control System L.D.P Circuit - Malfunction A
17879 P1471 EVAP Emission Control System L.D.P. Circuit - Short to B+ A
17883 P1475 EVAP Emission Control System L.D.P. - Malfunction Signal Circuit open A
17884 P1476 EVAP Emission Control System L.D.P. - Malfunction/Insufficient Vacuum A
17908 P1500 Fuel Pump Relay Circuit - Electrical Malfunction A
17910 P1502 Fuel Pump Relay Circuit - Short to B+ A
17912 P1504 Intake Air System Bypass Air Determined A
17913 P1505 CTP Switch not Closing - Open Circuit A
17914 P1506 CTP Switch not Opening - Short to Ground A
17917 P1509 IAC Circuit - Electrical Malfunction A
17918 P1510 IAC Circuit - Short to B+ A
17919 P1511 Intake Manifold Changeover Valve Circuit - Electrical Malfunction A
17920 P1512 Intake Manifold Changeover Valve Circuit - Short to B+ D
17951 P1543 Throttle Actuation Potentiometer - Signal too Low D
17952 P1544 Throttle Actuation Potentiometer - Signal too High A
P1545
P1559
17988 P1580 Throttle Actuator (B1) Fault - May be caused by low battery if found with 16487 (P0103) A
17990 P1582 Idle Adaption at Limit B
18008 P1600 Power Supply (B+) Terminal 15 - Low Voltage B
18010 P1602 Power Supply (B+) Terminal 30 - Low Voltage D
18014 P1606 Rough Road Spec. Engine Torque ABS-SG - Electrical Malfunction A
18019 P1611 MIL Call-up Circuit/Transmission Control Module - Short to Ground D
18020 P1612 ECM - Incorrectly Coded A
18021 P1613 MIL Call-up - Circuit Open or Short to B+ A
65535 P0603 Control Unit Failure or Internal Control Module Keep Alive Memory (KAM) Error or Power
Failure to Control Unit or Bad Ground Contacts or No Faults Recorded (If MIL Not Illuminated) A
65535 No Faults Recorded (If MIL Not Illuminated) A
65535 Control Unit Faulty (In Some Systems)
P0217 Temp Light - Engine Hot A
P0218 Temp Light - Transaxle Hot D+Temp Lamp
P0326 Knock Sensor - Constant Knock D+Temp Lamp
P0351 Ignition - Faulty D
P0352 Ignition - Faulty D
P0420 Converter - Low Efficiency D
P0443 EVAP Purge - Circuit Fault A
P0500 VSS Sensor - No Signal D
P0560 Battery Voltage - Out of Range A
P0561 Battery Voltage - Unstable D
P0562 Battery Voltage - Low D
P0563 Battery Voltage - High D
P0565 Cruise Control - Circuit Fault D
P0571 Brake Switch - Circuit Fault D
P0572 Brake Switch - Low Voltage D
P0573 Brake Switch - High Voltage D
P0600 PCM - No Serial Data D
P0601 EPROM - Fault A
P0602 PCM Program - Fault A
P0604 PCM RAM Memory - Fault A
P0606 PCM Processor - Fault A
P1782 Engine/Transmission Data Electrical Connection Ignition Intervention. Also check for loose ECM
power relay. A
Quick Reply: Frequently Asked Questions and Common Problems Thread Collection
