Cigarette lighter not working
Old 12-30-2004, 10:50 AM
avtiger's Avatar
Default Cigarette lighter not working
Hi, I have a '96 A4 2.8 Quattro and the cigarette lighter doesnt work. I think/hope its a fuse problem. has anyone had this happen? where is the fuse box? i looked all over and cant find anything. also, what type of fuse does it use?
if its not a fuse issue, what else could it be?
Thanks for your help
Old 12-30-2004, 11:00 AM
Justin517's Avatar
Default Re: Cigarette lighter not working
the fuse panel should be on the right side of the dash, open the door, and pry the panel off the side.
does the button stay inwhen u push it in on the lighter? i know the tabs on mine push out and it dosent liek staying in. i pryed them in (if u do this and your fuse isnt blown it prob will be after this) and it worked ok a few times but then went back to the way it was, now i have to hold it in lightly for a few seconds while it heats up then let it pop out.
to see if its the fuse or the tabs use somthing with an AC adapter, liek a radar detector or portable cd player, if it works then the fuse is fine
or just quit smoking, lol, thats what i did, getting a sinus infection helps alot too.
Old 12-30-2004, 11:08 AM
avtiger's Avatar
haha thanks. Im actually trying to use the cigarette lighter for a new laser detector, not smoking. i will try what you suggested
Old 12-30-2004, 11:24 AM
Andy_FL's Avatar
Check fuse #33 I *think*, just had to replace mine yesterday.
Old 12-30-2004, 12:55 PM
greggers's Avatar
Default Blew my fuse on one occasion with my cell charger.
It's a 15 ohm fuse (blue). If you have a manual there is a chart showing you where the fuse for the lighter is. I actually took the fuse from the fog lights and used it as a replacement until I could hit up the local Autozone.
Old 01-02-2017, 08:03 PM
Shannon Pigg's Avatar
if you have power at fuse and not at the bottom of socket remove the ashtray and reconect plug to lighter and it does work with aux adapter
fpjl
12
04-21-2021 07:01 AM
4lane
A4 (B8 Platform) Discussion
05-23-2018 12:36 AM
Khalizzel
12-08-2017 01:45 PM
pistol22pete
6
08-16-2016 12:00 PM
ivans A8
05-26-2006 06:31 AM
Quick Reply: Cigarette lighter not working
