Brake Pad Thickness
Old 12-22-2013, 09:56 AM
Redd's Avatar
By making a gross measurement (pad plus backing plate plus anything else) they eliminate the need for techs to make math errors while doing subtraction, so that makes good sense.
Most brake pads that I've seen have wear indicators molded into them, similar to the raised wear indicators in tires. Except in the brake pads it is usually a machined slot, and once the pad material is worn down so that there's no visible slot left, it is time to replace. That makes for a quick easy eyeball measurement, no special depth gauge needed. But of course, it also means eliminating some small bit of pad material, until it has worn down and needs replacement.
"No special service tools needed" appeals to this Yankee.
Old 12-24-2013, 07:58 AM
jjandersonn's Avatar
Originally Posted by spijun
They work as written in: Strict maintenance operations
Thanks!
This explains why they were indicating a 10mm min.
So if this measurement was 12mm, the pads alone are likely about 5-7mm?
The Q5 does have 55,000km, almost all city driving and her "driving style" is not particularly easy on brake pads either...
Old 12-24-2013, 10:14 AM
Redd's Avatar
Personally, I'd rather have worn pads replaced than renewed.
Do the dealers renew the pads by themselves, or send them out to a renewal depot?
Old 02-01-2014, 07:22 AM
FL C6.5 Avant's Avatar
nifty tool, but doesn't do anything for the inboard pad
I agree that pulling the wheel and getting in there with a flashlight is the best way.
Old 01-30-2017, 10:12 AM
Moorcroft's Avatar
Hi, when replacing the rear pads on a 2010 Q5 are the inner and outer pads interchangeable? All 4 in the box seem to look exactly the same but I'm not sure if there subtle differences that require them to be used in a specific combination?
Thanks
Old 01-28-2018, 07:29 AM
shokhead's Avatar
So how many mm are left when the worn pad warning comes on? 1 or 2mm?
Old 01-28-2018, 08:58 AM
Bob Petruska's Avatar
Inner and outer pads can wear much differently. The sensor on works on one pad and not both sides of the vehicle.
I have seen people ruin the rotor were a pad as totally gone (metal on the rotor) and the other pad didn't wear as much and not trigger the sensor.
If you remove the pads before the warning light comes on you will save yourself from buying a new sensor as you can remove and use the old one.
All the aftermarket pads I have seen don't come with the sensor, no sure about OEM.
Old 03-12-2021, 01:43 AM
  #18
Bongani45's Avatar
Originally Posted by lmariorod
I'd replace them when the brake pad wear sensor triggers. Otherwise, you'll be subject to the emotional upsell of replacing pads prematurely.
How would you know whether its front or rear pads which are worn out
Old 03-12-2021, 06:46 AM
  #19
apoelistas's Avatar
front have sensors.
Dont believe my rear pads have sensors..
maybe my mistake. The textar spare pads I have come with a sensor. Can anyone confirm this for the Q5 2.0l TFsi 8R??
what puzzles me is that the rear sensor coding was disabled when I purchased the Q5.
Yes there is a rear pad sensor coding but probably my sensor is/was not installed. Will check when rear ones need to be replaced.
How to check?? Flash light and measure thickness (from rims).
This aftermarket rear brake pad kit comes with all parts one will may need to replace.
Old 03-12-2021, 06:36 PM
  #20
gk1
gk1's Avatar
Originally Posted by apoelistas
front have sensors.
Same here just put new pads on 2014 SQ5. There is no rear sensor but one came in the box, along with the wrong vibration clips. It is clearly for a Q5 with solid rotors. sucks, but it'll be fine.
CarQuest (Advance Auto) Platinum Pro kit.
apoelistas (03-12-2021)
legerrej
09-25-2015 08:43 PM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
09-25-2015 08:57 AM
ECS Tuning-Audi
09-25-2015 08:20 AM
517
09-25-2015 05:24 AM
Bruce B
Q5/SQ5 MKI (8R) Discussion
09-25-2015 12:11 AM
Quick Reply: Brake Pad Thickness
