Timing Belt Replacement
Old 04-19-2014, 04:19 PM
mishar's Avatar
Default Timing Belt Replacement
Just a preview. Rest is coming when it's done.
Nativ Alhilal (08-02-2019)
Old 04-19-2014, 04:42 PM
Mike141's Avatar
Brings back memories...German engineering at its finest. How many miles did you get out of it?
Old 04-19-2014, 04:49 PM
ltooz_a6_a8_q7's Avatar
No cams lock?
Old 04-19-2014, 04:50 PM
mishar's Avatar
100K. Belt was fine, two rollers noisy, water pump too but not leaking yet.
Nightmare of engineering is installing crankshaft blocking tool.
Old 04-19-2014, 04:52 PM
mishar's Avatar
Originally Posted by ltooz_a6_a8_q7
No cams lock?
Not at this point. It would block access to the pump and thermostat. It comes on and of few times.
Old 04-19-2014, 05:19 PM
snatchman's Avatar
That strikes fear in me! As the owner of an A8, A6, and A4, I know I will have to take this task on sooner or later.
Old 04-19-2014, 05:32 PM
Mister Bally's Avatar
BTDT twice on my A8. The crank locking tool was pretty easy. IIRC, I remove the inner cv joint heat shield making access simple.
Old 04-19-2014, 05:47 PM
1Wasserwerks's Avatar
Holy crap!
Mishar, is this your spring cleaning project? I hope everything goes back where it came from. It looks like a pretty straight forward job though.
Old 04-19-2014, 06:11 PM
mishar's Avatar
I have to check that before the write up. The easiest way I figured was to give a pair of gloves to my wife so she can wrench it trough the wheel well while I navigate the wrench.
I am thinking about special tool that would come instead of vibration damper and be bolted to one of treads on the block.
Old 04-19-2014, 06:15 PM
mishar's Avatar
Originally Posted by 1Wasserwerks
Holy crap!
Actually it is. Sort of. I saw a few instructions and YouTube video that would mislead one for sure. But ELSA knows.
Quick Reply: Timing Belt Replacement
