Leaky front strut or electric issue, VCDS codes suggest latter?
So after I replaced my front left air shock (fixed the issue, weee) , I got around scanning the car and the codes logged from the old shock mention something about the Nsomething valve inside the shock not being responsive.
Is that the usual code for leaky strut, or was this some connection issue that i should've checked first, before replacing it? I sprayed the old shock down with soap water and saw no bubbles, though it was definitely hissing as the front left corder went down.
edit: fixed for clarity
AudiWorld Wiseguy
+1.
Is the car still maintaining ride level when in jacking mode? Only electrical component in the strut is the damper hardness adjustment valve/solenoid. If the electrical connection to the top of the strut is ok, then likely a faulty damper. Only way to fix is to replace. You also mention it's making a hissing noise too indicating an air leak. Is the replacement strut a new, used, or refurbed unit?
I should add, all the codes are from the OLD shock that i swapped out (no issues/codes with the new one), I was just curious whether the old one is any good given that the code implies electrical issues. Are there any internal vent valves on the shock itself?
Was it dropping overnight in Lift mode?
Arnott and the other rebuilders buy "cores". They may be able to repair the valve when replacing the air bladder.
When lowering my car the air release seems to be at the shocks. But I thought this is dumped at the control valve.
AudiWorld Wiseguy
I replaced it with a new one, happened to find the oem one online for a good price.
AudiWorld Wiseguy
The system vents to atmosphere via a silencer and air dryer around the compressor. The struts sound like they're venting, but that's just the noise of the air going back through the check valve and pipe work by the strut....unless you have an airbag leak of course
I thought so as well, didn't see any outlet for the air to vent on the shock body itself.
Brandon Crull
19
07-11-2018 08:57 AM
NickAudiA4
19
08-11-2007 08:43 AM
TTDirk
TT (Mk1) Discussion
11
02-14-2006 05:03 PM
Lloyd of the Rings
TT (Mk1) Discussion
09-02-2001 02:38 PM
