VCDS Ride Height Adjustment
My car has the sport suspension - will I still be starting with 0015510? or will it already be at 0011110?
Also, as far as measuring wheel centre to arch lip, I'm running +25mm od oversized wheels so do I need to take 12.5mm off my numbers before inputting into VCDS?
Looking to do it on a friends VCDS any day soon so want to be prepared.
Thanks.
Thanks.
Center of your wheel is at the same distance from the arch no matter what wheels or tires you are running. That's why they use this measure. So no adding.
So could I leave my lowering links installed then seeing as they are on and giving it the correct measurements will give same effect as having std links on?
I didn't mention because I assumed I would need to refit the stock ones.
Just been out and measured and currently centre to arch lip is 350mm all round. So if stock is 416 & 398 and mine being a sport is 396 & 378, I'm assuming it means I'm lowered 46mm front and 28mm back?
Rick123 (02-28-2024)
#18
I would suggest you to lift it to stock 396/378 before you start VCDS lowering, than lower it as much as you can (may be even to 350/350) and than adjust it with links.
