S-Tronic Owners: Gearbox Malfunction
The funny thing is, the car sat in my garage for 3 days prior to this happenening. I drove to work (15 mins), it sat for an hour then when I pulled off I got the warning.
Luckily I've not experienced any issues with my transmission.
I've tracked it in 100F+ temps (20-30 minute sessions) with oil temps in the 270's and the transmission never once gave me an issue. Granted I have no idea what the transmission temps were but I assume "hot" would be the proper term.
There were however BMW's that had to go home or stop driving because their transmissions went into limp mode.... lol
oil needs to flow through out the gearbox... if it settles it won't do it job and things may overheat or get damaged....
Well like most said it most likely is some faulty sensor somewhere.. all i was trying to tell u is that if u leave ure car parked on a hill or grade.. whether at work or at home it may eventually damage the box... the gear box oil may be settling more where its not meant to be... just keep an eye out that is all
simple, if the oil has settled in a specific place in the tranny then obviously the tranny is not being lubed and may overheat or malfunction... just how cars work... audi even says if u tow the car at an angle it may damage the gear box. thats why u need to flat bed it...
#18
Gearbox malfunction
I just had my audi s4 towed to dealer for gearbox malfunction with limited functions then parking brake malfuntion then the car shut off while i was driving after i restarted it happened again. I drove home now its on its way to dealer and they are acting like they know nothing about this issue but seems to be happening to others what can i expect? Anyone know or advice on how to deal with these people acting stupid?
#19
Don't know if you got the recent Additional Warranty and Maintenance Information Supplement for 2015-16...nor if it matters in your case, but post here as general info (maybe I missed another post)?.
"Perform first at 40k miles and every 40k after they. -DSG/Stronic: Change ATF oil and replace transmission filter element for clutch hydraulics"
#20
OK so I've been on Google all morning as I was literally on my way to Audi Dealer this morning for a routine service when I got this "Gearbox Malfunction - you can continue driving".
In a way, its a good thing it happened on the way, as I'll get a proper diagnosis. In a bad way, I'm so worried of the outcome.
I have a 2011 S-Tronic 7 Speed Quattro 3.0 TDI A6
I'm absolutely bricking it as they are scanning for diagnostics any time now. I've read some horror stories online...
My car is obviously well out of warranty!
The car seemed to have lost torque, but I've read this is a safety precaution. It still flows very smoothly from 1-7 with no issues. All I did notice, was it wouldn't change to S-Mode by pushing gear selector downwards. I'm guessing this is also to do with protecting the engine/transmission with possible overheating?
Will post later with updates.
