3.0 Tfsi carbon build up: yes or no ?
Old 11-01-2013, 10:30 AM
q5q7's Avatar
Default 3.0 Tfsi carbon build up: yes or no ?
if yes can anyone share a link with pictures?
I got conflicting info all over the forum.
Thanks..
Old 11-12-2013, 01:28 PM
gojones's Avatar
Default Any Carbon Issues reported with this engine
I too am wondering if the combination of multiport and direct injection is actually used with this engine and if it has limited the carbon build up issues with earlier DI engines.
Old 11-13-2013, 11:40 AM
q5q7's Avatar
3.0tfsi only direct injection, no port injection.
also yes it does buildup carbon just not as bad as other ealier audi engines.
Old 07-23-2014, 07:21 PM
dpcompt's Avatar
Default Carbon buildup in3.0T?
Do you have evidence of this?
Old 08-23-2014, 06:35 PM
dpcompt's Avatar
Default carbon build up
Your not replying shows that your comment about the 3 liter supercharged engine is a total B.S. statement.
Old 11-10-2018, 01:25 PM
angrypengu's Avatar
Finally someone with some brains. Sorry to bring up this thread, but for the love of heavens I see this topic being discussed again and again and again with incorrect information.
1) 3.0 TFSI engines (we're talking the supercharged 3.0L V6) does have dual injection in European motors only. The port fuel injector (x1) is introduced only in Europe to meet NOX emission standards.
2) This NOX restriction does not come into play in NA, so thus for us NA folks, the 3.0 TSI (we'll call it that for short) engine does NOT have a port fuel injector.
That doesn't mean there is a rampant issue with carbon buildup on these latest engines (because there isn't). Audi and Mercedes have finally figured out how to make an air oil separator that is half decent. It only took Audi 10 years to figure this out though.
I hope this finally buries this thread topic.
So in conclusion to the OP's question.
Yes, I'm sure there is carbon buildup due to the inherent nature of DI engines, but there is no systemic issue like before where there were problems with CEL or performance issues. In fact, on the M276 engine which is DI which is built by MB, I've now seen motors with 150,000 miles with barely any carbon buildup on the intake valves. Unfortunately for us folks, I've stepped away from Audi for a few years after a disaster of a RS4 ownership experience (and an A4), both B7s of course, but now carefully coming back to the D5 A8 because I do think based on the 3.0 TSI's performance lately that it appears Audi has fixed this issue.
Old 11-18-2018, 06:54 AM
AudiAllTheWay's Avatar
While I was replacing my injectors in my 2011 A6 3.0T at 55,000KM's I took advantage of the opportunity to perform the "Decarb Service" on the cylinder head intake ports. With injectors removed there is no compression so it is easy to turn the engine over by the crank pulley and I found one position that had 4 of 6 cylinder intake valves closed, so I blocked the other two cylinders intake ports with a rag and proceeded to fill the intake side of 4 closed cylinders with brake clean and used a variety of hand tools to remove tons of built up carbon. Then rotated crank to close all valves on the remaining two cylinders and block off the other 4 in order to perform the same cleaning process. I was shocked how much carbon was built up on the intake port walls and on the valve stems at this "low" mileage, and it was painfully clear over time even with top tier grade highest octane fuel and high quality spec synthetic oil that the cylinder head ports were slowly being chocked off with carbon buildup. It was a few hours of filthy work and when done the intake ports and back of valves including stems looked brand new. Be careful not to scratch the port walls as it is aluminum. With the ports closing in on themselves due to accumulating carbon buildup it increasingly disturbs the designed "swirl effect" of air entering the combustion chamber which slowly over time will continually reduce engine power and reduce fuel efficiency. The magic number is around 100,000KM when the carbon buildup becomes so bad that the first symptom will appear which is rough idle after cold engine start, and idle smooths out while engine warms up.
Anyone who thinks the 3.0T is immune to intake carbon buildup should remove their supercharger and intake runners and inspect the intake ports for yourself. The issue is no matter how good the PCV / Oil Separator does it's job, there is always going to be a trace amount of fine oil mist that passes through back into the intake and the heat of the valves and intake ports cook off the liquid and what is left behind inside the intake ports is slowly accumulating carbon deposits. Some things are different in Europe, but in North America everyone needs to accept the fact that Audi / VW DI Engines from the beginning of DI introduction to at least 2011 including the 3.0T require a "Decarb Service" as part of long term Regular Maintenance.
I am curious if the brand new models still have this issue?
Old 11-27-2018, 07:51 AM
09mazda6's Avatar
Good post and pics - do you have any more pics or a write up on what you did to remove these parts and replacements that you did. For instance I see you have some yellow plastic cap or something in the coolant hoses? Did they work well and did you buy those or are they simply bottle caps.. those types of tips/tricks are always appreciated by other DIYs like myself who till be doing similar work hopefully next spring.
Old 12-13-2018, 03:28 PM
mlhaney's Avatar
i have a 2014 a6 3.0t with 56000 miles. just had to have the intake manifold gasket upper cleaned. carbon build up was very bad. sad thing is it is not covered under warranty. Audi claims my vehicle is one of the recalls or extended warranty on it. But it has the problem. very expensive to have cleaned. labor was $2800.00. total bill was $3800.00
Old 12-22-2018, 01:07 PM
angrypengu's Avatar
The 2011 models were subject to extended warranty to cover this issue.There have been no cases that I can recall for models since (IIRC) 2014 (or the tail end of 2013) for the 3.0L engine that had extensive carbon buildup. I suspect they updated the air oil separator module.
ECS Tuning-Audi
A4 (B7 Platform) Discussion
07-11-2018 11:15 AM
steven7270
A4 (B9 Platform) Discussion
04-17-2017 12:35 PM
LR95S97
10-20-2015 10:27 AM
drvai
12-16-2013 02:14 PM
Kevagonia
03-18-2011 03:06 PM
Quick Reply: 3.0 Tfsi carbon build up: yes or no ?
