Locking doors while leaving car running?
Old 09-27-2013, 06:54 AM
DennisMitchell's Avatar
Don't have advanced key, but this should work. Separate the physical key from the FOB. Leave FOB in car running. Exit car, stick physical key in door lock and lock doors.
Reenter using physical key. I do this for cold winter startups.
Old 09-27-2013, 08:08 AM
AUDIIOS's Avatar
I do this too -- it works. I have the Advance Key and you can take the fob with you, don't have to leave it in the car. Also when you manually lock with the key, the fob or touch sensor will not open the vehicle until it has been unlocked again manually.
Old 09-27-2013, 08:17 AM
smonakey's Avatar
Originally Posted by Reggie
Why bring the dogs then? Puffing is illegal in most states
Bringing the dogs so I don't have to drag them home & then go to school.
Old 09-27-2013, 08:19 AM
smonakey's Avatar
Brilliant! Thank you, I'll try that!
Old 09-27-2013, 08:23 AM
smonakey's Avatar
Originally Posted by besyugan
we had a similar problem until my wife trained the dogs to pick up the kid. The school complained and so we had to switch to a jeep cherokee
have you thought of just cracking a window open for the dogs? not in a literal sense of course.
What's puffing? I'm so not up on lingo!
Old 09-27-2013, 08:57 AM
Yoshimura's Avatar
Is it possible to get a spare key from a locksmith?
Old 09-27-2013, 09:55 AM
If you look at key, it is milled. Probably there are some locksmiths who can do, otherwise go to Audi.
Old 09-27-2013, 10:48 AM
  #18
smonakey's Avatar
The keys are absurdly expensive, though. I'll just use the hard key in the key fob. Forgot that was there & it's a simple & easy thing to do.
Old 09-27-2013, 01:22 PM
  #19
spijun's Avatar
It is impossible to do.
If someone makes a copy you can not use it because of the Audi system protection
Old 09-27-2013, 01:36 PM
  #20
Telate's Avatar
What about that lousy plastic "emergency" key that they give you. does it actually have a chip in it? It works to open/close the doors as well as start the car...
Quick Reply: Locking doors while leaving car running?
