Transmission fluid change
Old 09-27-2011, 03:28 AM
joenok's Avatar
Originally Posted by 5v/cyl
Doesn't matter. Wheels on ground or in the air as long as it is level. I run mine up on four ramps and put suspension in level 4 for plenty of room underneath when changing.
Thanks!
Old 09-27-2011, 07:50 AM
Mr. Timewise's Avatar
But realize that you will be putting the transmission in gear while the wheels are on the ramps. Solidly engage the hand activated parking brake and make certain your assistant applies the foot brake with full lock force so the car does not start to move when he/she cycles the transmission the required multiple times (from Park to Reverse to Neutral to Drive, repeat).
Old 09-27-2011, 11:01 AM
amiram's Avatar
Default changing trans' oil
By the way, if you drain the oil transmition through the draining plug will come out only about 3 liters of oil. And in transmition ther is 9 liters of oil.
r1racer
A6 (C7 Platform) Discussion
10-09-2016 02:44 PM
TorontoA64.2
Canadian Discussion
04-29-2012 09:40 PM
Turnyface
Audi 100 / A6 (C4 Platform)
07-10-2010 06:33 AM
vlam04
07-08-2010 08:31 AM
2PUTT
05-06-2006 08:21 PM
Quick Reply: Transmission fluid change
