im swaping the 2.2 n/a to 2.2 i5 turbo...auto tranny 2 5 speed swith? what to change
Old 01-23-2014, 11:27 PM
igor.p0984@gmail.com's Avatar
Default im swaping the 2.2 n/a to 2.2 i5 turbo...auto tranny 2 5 speed swith? what to change
im swaping my stok non turbo motor for 82 audi 200 turbo 2.2 i5 motor that was automatic. my stock tranny that im using is of 85 gt coupe non turbo 5 speed, what do i need to change on the block so that i can bold the flywheel and cluth to the turbo motor? is it just gona bolt up or do i need to switch the 5 speed real seal and put it on the turbo motor?
NEED HELP PLEASE.. THANK U..
Old 01-24-2014, 02:18 PM
Rogviler's Avatar
The flywheel will bolt right up, but you will need to change the pilot bearing. The pilot bearing part number is 046105313D. That is the only thing you should need to change.
Getting the old one out can be a pain. I would look through some Youtube videos (any pilot bearing, not necessarily Audi) and see which method looks best to you. I happen to be a fan of packing something in there to force the bearing out hydraulically. I've seen grease, wet paper, and even bread work flawlessly. That beats trying to cut or chisel it out and potentially damaging something.
-Rog
Old 03-20-2014, 11:18 PM
[QUOTE=igor.p0984@gmail.com;24533587]im swaping my stok non turbo motor for 82 audi 200 turbo 2.2 i5 motor that was automatic. my stock tranny that im using is of 85 gt coupe non turbo 5 speed. So got the pilor bearings switched.
But some one told me that the stock non turbo tranny will not work well with turbo motor.
The turbo motor has higher rev.
Is it true. Do i have to get a turbo trany or can i replace the sincros and gears inside with turbo ones.
thanx for all the help i can get
Old 03-21-2014, 06:58 AM
Rogviler's Avatar
It will work just fine. It's exactly the same motor, just with a turbo and some other incidental things that make it stronger for use with a turbo. But it operates exactly the same as far as the rest of the drive train knows.
-Rog
Old 03-23-2014, 12:13 AM
thank u for all ur help.
Newtonmason72
TT (Mk1) Discussion
10-25-2015 03:56 PM
allmotorryan
02-28-2010 09:56 AM
Bryancald
1.8T Discussion
08-19-2006 10:50 AM
soul97
08-22-2003 06:51 PM
Tylerb929
04-12-2002 05:38 PM
Quick Reply: im swaping the 2.2 n/a to 2.2 i5 turbo...auto tranny 2 5 speed swith? what to change
