22" Wheels & Tires
Old 04-03-2013, 11:38 AM
eboylefsc's Avatar
Default 22" Wheels & Tires
I'm driving a 2012 Q7 Prestige (S-line) and want to get new rims and tires. The rims I selected (Giovanna Dramadio) come in a 9" or 10.5" but both recommend a 285/35/22 tire. Should I purchase the 9" or 10.5" width? Also, what recommendations do you have for 285/35/22 all-season tires?
Old 04-03-2013, 12:58 PM
arp2nr's Avatar
I had 265/35/22 but I had to use 14mm spacers to clear the front calipers. Make sure you have the right offset on the my rims 45 and I still needed spacers.
I recently will be running 295/35r21 on BBS RX519 21x10.5 front & rear these have an offset of 52. I'm waiting for the ties but I test fited the rims and they seem to clear
Old 04-05-2013, 01:25 PM
edgeq7's Avatar
10 or 10.5. Don't believe recommended tire sizes for Q7 285/35R22 or 295/25R22 are designed to run on anything less than 10 safely. I run 285/35R 22. Have used Toyos Proxes ST II and Yokohama. Like the Toyo for summer not so much for year round. Yokohama's were better year round. The rims I have are 55 offset no spacers.
Old 04-14-2013, 06:11 AM
a_boyarskiy@yahoo.com's Avatar
Default Audi Q7 S-Line 22" Rohana RC10
Just installed 22X9 Rohana RC10 offset +42 all around.
Tires Yokohama Parada Spec-X 285/40R22; wanted a little more of
sidewall. Tell me please what do you think.
Old 04-14-2013, 03:17 PM
edgeq7's Avatar
Nice!!! Wish I had more side wall.
Old 04-14-2013, 08:21 PM
NWQ7's Avatar
Looks sharp. Very clean.
Old 02-01-2014, 03:30 PM
phillips2024's Avatar
I like the added sidewall but how are these holding up for you? any issues with the 40 sidewall? I ask because that is over a 4% difference over OEM
Old 02-03-2014, 05:43 AM
I do not have any problem and it looks sharp.
Old 02-03-2014, 06:01 AM
It depends on your personal preferences. If you like agressive look, go with 10.5, if you are more conservative, go with 9.
285/35R22 is too low for me. But if you are LOW RIDER, go with it. I use Yokohama Parada Spec-X 285/40R22 all-season tires.
Old 02-03-2014, 02:09 PM
Snopyro's Avatar
Go for the 10.5". I went to a local tire shop and they said that if you want more sidewall, you can run a 265/40-22 on a 9"-10" wheel. (You need to ask if this tire size will work with a 10.5" wide wheel.) Wheel diameter will be slightly larger with this tire, but it will provide more cushioning against potholes damaging your 22's.
They were trying to sell me a wheel/tire pkg deal with Nexen Roadian tires, but I've never heard of them. Anyone here have any feedback on the Nexan tires? Otherwise, I'll go with a bigger name brand tire.
Quick Reply: 22" Wheels & Tires
