Problem passing smog in CA
Old 03-22-2014, 10:51 PM
Mikaere808's Avatar
Default Problem passing smog in CA
My 2001 tt will not send communicate with the smog machine. Has anyone had his problem or know of a fix for it? I need to get it smogged so I can register it.
Thanks
Old 03-23-2014, 04:15 AM
Mister Bally's Avatar
Thanks
Get your hands on a wiring diagram (Bentley manual on CD) and trace the wiring from the diagnostic port to the main ECU as well as 12 volt & ground lines. Probably a break somewhere or a bad ECU communication circuit.
A good shop visit would probably be best but someone could have disconnected or cut something which is easy to diagnose using standard automotive electrical troubleshooting techniques.
Old 03-23-2014, 10:51 PM
Mikaere808's Avatar
I was also told because the battery died that it reset the ECU. And that I need to drive it for awhile at 55mph or above to get the ECU working again. Is that true? Hopefully that's true cause that will be a much cheaper fix than taking it to a shop.
Old 03-27-2014, 04:47 PM
AudiMick's Avatar
Nothing to do with the battery, you may need to drive it to get readiness codes but the scanner should still work.
Do you have an aftermarket radio?
There's a problem with some harnesses shorting the K-line to 12 volt. It will block communications.
The other common failures that block the K-line are the cluster, ABS module and comfort / alarm module. Unplug them one at a time to find the culprit.
errolmenendez
Audi Original "S" Cars
10
08-17-2014 08:41 PM
unselfishly
08-20-2005 11:16 AM
nickelmedia
07-19-2005 11:16 AM
a4gal
01-24-2005 06:49 PM
Quick Reply: Problem passing smog in CA
