Old 07-13-2016, 10:35 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Audi A6 (C6) Specifications & General Maintenance
Print Wikipost
Oil pressure warning light question
Old 03-13-2010, 07:13 PM
scout2's Avatar
UPDATE:
Oil change/sensor change seems to have fixed it. I ran it for 20+ minutes up and down the road watching the vagcom and 99% of the time it was ok - sensor reading ok. No warning light, got oil up to temperature, probably went about 15 miles mixed in town/highway. Everyonce in awhile looking back through the log it was reading low pressure, but it was only at idle and then only when it dropped below 700ish RPM. Any chance this is normal and the car knows not to fault on these errors? It wont' read them in park, but it will in drive idling and its only sometimes when the rpm drops down.
Mostly - I'm glad there's no light and I don't have bad problems.
High points:
-easiest to get to it while oil filter is out.
-Sensor on the 2.7 is right above oil filter housing it screws in towards the front of the car (plug faces back of the car when installed).
-24mm deep socket for the sensor
-had to drop sway bar (left ends attached)
-had to pull the rubber intercooler(I think that's what it is) hose and steel one (not fun).
-Steel section screws into sump with 2 #5 allens.
Thanks for your help guys.
A4orce84
06-25-2005 03:01 PM
Libtek13
12v V6 Discussion
15
08-04-2004 11:56 AM
DirtySanchez
07-16-2002 07:56 AM
Audi-Impaired
04-19-2002 09:04 AM
S6Erik
12-11-2000 01:59 PM
Quick Reply: Oil pressure warning light question
