2010 S5 amp and sub install write-up
#21
Tomorro
After cruising the internet, and doing a bit of research, I have decided to install (have someone install) the sub in my car.
I am installing a JL10W7 in a sealed box (more of a SQ guy than SPL) with a HD750/1 to push it. All said and done, should total ab $1200 bucks with everything new. I will post pics tom, but I am looking forward to having the bass rockin as I hit that 155 speed limiter
This should be a professional install, so hopefully itll be helpful to anyone looking for more pics (in addition to elf_cruisers good looking setup)
#22
Am going to do 2x10W6v2 myself in custom sealed enclosures on either side of the trunk walls. I'd like your opinon on the W7's. They are just so damn deep. Waiting for Audison to do this BitOne update so the unit will work with the 3G MMI. For those of you wanting one, It works with the 2G MMI.
#23
Man, the sub sounds great, I got the sealed enclosure, so its a tight bass, and it truly doenst sit too far in the trunk at all. The specs for the sealed enclosure are on the JL website, I would encourage you to look at em and then do a bit of measuring in your trunk ,it fits like a glove in the back corner (back of sub at back of the seat). I can still get 2 sets of golf clubs in my trunk, and have it pound. Also, you can set a HD750/1 sub right underneath the factory subwoofer, so all you see is the sub box, nothing else obstructs the trunk...
Sounds fantastic, has enough SPL to shake the car as much as Id need, and enough snappiness to keep up with my techno. I got everything done for about $1100 bucks) (400 for amp shipped) (500 for box and sub shipped) like 200 for install.
I was between this and an exhaust, and frankly, im happier with this (since you couldnt ever hear both)
#24
Thnks
#26
Ditto - i'd like to see how the pros did it, and change my setup if there's a better way to do it...
With the 10 - I bet you can still open the trunk floor and get the spare out, huh? I took mine out with the tools and will just throw it in the trunk for road trips - no need having it in town (AAA card can get me home).
#27
Still trying to put something together for mine when it comes. Plan to keep the stock speakers, at least at first except for the subs. Gonna do two JL Audio 10W6v2's. Gonna replace the amps and am trying to figger out exactly how many hoops I'm gonna have to jump through to do this Audison Bit1 thing.. Plan to Bi-amp the front doors, one channel to center, two to rears and two mono subs=eight channels.
#29
Might be able to make the assumption that some of the gear in the S5 is the same as the Q7 -
http://www.audiusa.com/us/brand/en/e...__olufsen.html
Also - with the Audison configuration that you described, you'll have some dead speakers, which may really affect the clarity of the system. The B&O has bass drivers and tweets in the front doors, mids in the dash and rear deck, and another set of bass and tweets in the rear side panels, all in addition to the sub channel. I would wait til you get the car before you start planning out the stereo. I'm a pro drummer with a lot of studio time, stage time, and hearing loss, especially in the higher frequency ranges above 5Khz, and I still keep the treble setting reasonable, and full vol in this system is pretty much loud enough. I wouldn't want it much louder even if money was no object. It could be cleaner, but it's really splitting hairs at some point. This B&O is good enough to require SACD or other hidef media before you really hear the imperfections in the system. CDA or MP3 is no contest for the B&O ... It makes MP3's sound like the junk that they really are...
#30
Having listened to the B&O system in my new S5 for the past couple of weeks, I have come to the conclusion that all it really needs is a subwoofer to fill in the lows. The sound quality at higher frequencies is quite good - very clear while listening to CD quality files. Having gone from a car that had a professionally installed, high quality system, there is a definite loss in sound quality in the B&O, but I'm pretty sure it's only due to the lack of a powerfull subwoofer.
I just need to figure out the cleanest way to do the install.
