How To: Airbag Control Module Replacement
Old 08-26-2009, 05:58 PM
  #21
javialquim's Avatar
In the radio removal step: What keys are you referring to? My ignition keys do not fit in those slots. Is there anything else I can try? I tried spark plug gapper - it fit the slot but did nothing. I also tried butter and regular knives.
Please help!
I'm changing the whole shifter (previous owner destroyed it). I am stranded until I get this car rolling again.
Thanks,
Javi
Old 08-26-2009, 06:01 PM
  #22
Tech Guru
4Driver4's Avatar
You need radio removal keys.
Old 08-26-2009, 06:16 PM
  #23
javialquim's Avatar
A little more searching needed on my part...
In case anyone else is looking, this worked perfect:
https://www.audiworld.com/forums/sho...t=remove+radio
Old 11-01-2009, 01:09 PM
  #24
rs4-380's Avatar
just did this today and wanted to say thanks. For what it is worth I found a module at a junkyard for 125 bucks.
Old 03-12-2011, 01:57 AM
  #25
tsandfor's Avatar
Default Success! Replacing Airbag Control Module
Thanks very much for the excellent procedure. My 2001 A6 2.7T 175,000 miles had the airbag light on and the VAG COM said the ACM lost it's memory. Dealer wanted about $700 for the part. I called the fine folks at B&R Auto Wrecking 800-327-7380 and was able to get the exact part 4B0 959 655 F (I have the airbags above the doors) for about $100 including shipping. I did not even have to re code it with the VAG COM. Plugged it in, started the car, no more light!
Took my old ACM apart, no sign of any damage. Just a bunch of electronic parts and some type of accelerometer.
With my A6, I did not need to unplug the parking brake wire. Also, for others, be sure to have the special tools to remove the radio. The tools look like small knife blades that get stabbed into the 4 small slots in the radio face. 4 are required. I bought 2 off of Ebay and made the other 2 from an old hacksaw blade on my bench grinder.
Thanks again for taking the time to share with others!
Old 01-11-2014, 01:49 PM
  #26
meinaudiauto's Avatar
Default Vag
Is it always necessary to recode the unit?
Given that I do not have a Vag-Com it would be great for me to do it without coding.
Matching the part number exactly maybe?
Old 01-11-2014, 01:54 PM
  #27
GTA_Driver's Avatar
Nope. Get vag-com.
Old 01-29-2014, 10:18 AM
  #28
Default Got a problem
I replaced my airbag control module (had fault code 65535) yesterday, following this tutorial.
All went fine, I soft-coded the unit, cleared the fault codes and the airbag light went off.
I drove it for about 10 minutes without any issues or lights.
This morning I start it up and the airbag light is back on with the same error code - 65535.
Any idea what is happening here?
It seems like this time and the last time the light came on after an extreme cold night. Wonder if that has anything to do with it.
Old 01-29-2014, 10:56 AM
  #29
SloopJohnB@mac.com's Avatar
clear the code again.
Old 01-29-2014, 12:14 PM
  #30
Default -
I tried that but it gives me:
"The request to Clear Codes was not acknowledged by the control module."
Quick Reply: How To: Airbag Control Module Replacement
