How To: Airbag Control Module Replacement
Old 02-11-2008, 10:02 AM
OneGuyInCA's Avatar
Yup... darn thing snapped right of a couple of years ago. Maybe superglue next.
Old 02-11-2008, 10:16 AM
Audeye A6's Avatar
Nice job, I hope I never have to refer to this. :-)
Old 02-11-2008, 10:53 AM
02 Silver Arrow's Avatar
Default Very nice write up. Also handy for any of the smaller jobs in bewteen a complete romoval Thanks
Also nice to know you don't have to remove the air frshener for this job
Old 02-11-2008, 11:04 AM
boostbuddy's Avatar
Default Nice job... Where in Cali do you live - NorCal, SF Bay Area?
Looking for good wrenchers to work with.
Old 02-11-2008, 11:32 AM
OneGuyInCA's Avatar
Thnx.... Sacramento
Old 02-11-2008, 12:50 PM
GBW
GBW's Avatar
Nice job, BTDT...good to have it documented for those who follow...
Old 02-11-2008, 01:10 PM
AudiWorld Expert
2.7tDallas's Avatar
Default great time to run cables for stereo upgrades if you will ever do it
and to install an extra lighter plug
Old 02-13-2008, 07:49 AM
  #18
C5 Chas's Avatar
Default Thanks for a nice write up!!!
I don't need to exactly what you did, but I did want to take apart my center consol and this helps in a huge way! Again, nice job and THANK YOU!
Old 04-05-2009, 05:38 PM
  #19
pologoped2's Avatar
Thank you for the great tutorial, this made the job much easier. I am still running into an issue though after the replacement of the module.
I have just finished completing the replacement of my Airbag control module with a brand new one from the dealership ($755) to rid myself from the infamous 65535 - Internal Control Module Memory Error. Upon putting everything back together and reconnecting the battery I started the car and the airbag light still remained on.
I then realized that I had to soft code the new module, so I took the soft code from the old module and entered it into the new module using a cable off of eBay and a shareware version of 409.1 Vagcom software.
Once I was done with this, the Airbag light remained on and the below fault codes were shown:
VAG-COM Version: Release 409.1-US
Control Module Part Number: 4B0 959 655 F
Component and/or Version: Airbag Front+Kopf 2002
Software Coding: 00307
Work Shop Code: WSC 00000
10 Faults Found:
01587 - Igniter 2 for Airbag: Drivers Side (N250)
32-10 - Resistance too High - Intermittent
00590 - Shareware Version. To Decode all DTCs
32-10 - Please Register/Activate - Intermittent
01219 - Shareware Version. To Decode all DTCs
01220 - Rear Airbag Igniter: Passenger Side (N202)
01578 - Shareware Version. To Decode all DTCs
31-10 - Please Register/Activate - Intermittent
01044 - Shareware Version. To Decode all DTCs
35-10 - Please Register/Activate - Intermittent
01591 - Indicator Lamp for Airbag Off: Drivers Side (K144)
31-10 - Open or Short to Ground - Intermittent
00656 - Shareware Version. To Decode all DTCs
36-10 - Please Register/Activate - Intermittent
01216 - Shareware Version. To Decode all DTCs
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
30-10 - Open or Short to B+ - Intermittent
I then tried entering the previous workshop code, but still the above errors were shown. In the Robert Bentley manual it states that after the replacement of this module if these DTC codes come up, you can clear them.
Has anyone ever experienced these fault codes after the replacement of the airbag control module and did clearing them fix the issue? Given the power of a Vagcom I am thinking about buying the full version and cable from Ross-tech so that I can attempt to clear the above codes. Do you think though that this is normal to see these DTC codes, given that it is a brand new module?
My concern is that the shareware version (with the eBay cable) might have messed something up when it soft coded it. Also, let me know if you think it is a problem to drive the Audi until the cable from Rosstech arrives.
2001 Audi A6 2.7T
Thank you in advance for your replies,
Matt
Old 04-05-2009, 05:40 PM
  #20
Tech Guru
4Driver4's Avatar
Sell the cable you have on ebay and buy a real cable from Ross-Tech.
Quick Reply: How To: Airbag Control Module Replacement
